I'm sure you all try out your pedals before you seal em up. ;)
How do I ground it before I put it in the box? When I'm trying it, I can get sound out, but a ton of buzzing.....
Ground the jacks, both of them.
Ground the pcb and both jacks to the -negative on the battery or powersupply.
Get alligator wire so you can hook up the jacks temporarily. :)
I have a separate test enclosure that already has the jacks, switch, and led wired and ready, just have to attach the 4 wires from the pcb to test it out.
