If I've done my homework right, I should be able to configure the order switch-pads on the LaserWolf to get an OverDrive - Phaser - Delay circuit order using the connections indicated in the attached image. I' just looking for another set of LaserWolf-aware eyes to verify. tia
It appears I did my homework right and the order change worked as hoped in the original post. My LaserWolf is now ordered as OverDrive - Phaser - Delay. (using the jumpers noted in the original post)
