Did anybody else catch Steve at Smallbear's update on this?
"Twinkie/A-size" box builders: I have set a licensing agreement with Chase Bliss Audio for the "Tall Twinkie" that they originated. Stock coming for Spring."
This could be a game changer for all those crazy like I am :D
This sounds goofy, but intriguing. A 1590a with more than 1/8th inch of build height... wacky
Oh, sweet. I have at least one pedal that this will help make a reality.
This should help open the door for some more 1590A brick reverbs (even though FV-1 is the future of getting all sorts of amazing reverb sounds in a small package)...
Interesting! Would certainly be helpful in the build process. I wonder if it would make it more prone to wobbling on a pedalboard. My 1590A builds already do that a bit, even with a "full bleed" velcro job on the bottom plate.
Chase Bliss started those? Haven't other manufacturers been using them for years? I could've sworn Xotic used taller 1590A enclosures for something at one point.
Quote from: pickdropper on February 14, 2018, 02:44:34 PM
I think Steve is just buying them from Chase Bliss, but they are probably the same ones Xotic uses. In the Chase Bliss copy for the Favorites Mini Controller, it even says it's the same height as the SP compressor.
Quote from: dan.schumaker on February 14, 2018, 05:09:13 PM
That makes more sense to me. Thanks.
It's like skyscrapers, go vertical! "Somewhere deep in the aluminum chasms my lad, are the connecting cables that make this rig possible!"
