Top mounted jacks are something I struggle with normally. Too close to the corners, not far enough away from the pots, all the usual things.
This time though, I drilled out the face of the pedal, and flipped it up to drill the jacks, and then realised I'd drilled the wrong end after doing both holes.
I'd like to say that I hadn't put the label on yet, but that isn't an excuse as the template had the graphic on it too. FB has suggested LEDs in the holes, but I'm leaning towards plugs if I can find them...
I've definitely been there before (more than once). Its the worst, a waste of a perfectly good box. The worst time is when you are on your last box of that size and have to wait to fix your mistake....
Any chance you could get some soft switching modules to save some space and keep using the box? I can't remember if the momentary stomp switches are shorter or not.
I've used JB Weld to fill in misdrills and also to redrill an old enclosure for recycling into a new pedal. It works pretty well. An example:
Before repainting (I did add a bit more JB Weld to fill in some divots after I took this pic).
(http://i.imgur.com/3P90Gzkl.jpg)
Redrilled and repainted (technically, I'm still painting this one).
(http://i.imgur.com/Y4SyZf9l.jpg)
I've used a little electrical tape on the inside and enviro to fill the holes. Works out ok. LEDs sound cool too.
I have a couple of these left if you want one.
You just drop it on the edge of the enclosure and mark the holes, sets them right where they need to be. ;)
(http://pedalpcb.com/images/DG1.jpg)
(http://pedalpcb.com/images/DG2.jpg)
Quote from: BuGG on July 12, 2018, 07:17:29 AM
That is awesome! Super clever to make that up. I need one of those!
Nylon hole plugs, black, low profile, are sold by Mouser, a couple different manufacturers and a wide selection of diameters. They look good, like they're meant to be there.
https://www.mouser.ca/ProductDetail/Keystone-Electronics/8600?qs=sGAEpiMZZMsQtlBhqKq43aMDmho0KU6S
I need one of those
I need this! ;D
(https://i.kym-cdn.com/entries/icons/original/000/005/574/takemymoney.jpg)
Damn, just put those up on the site and they'll fly of the shelves...ummm...baker's racks...
Quote from: gordo on July 12, 2018, 06:53:15 PM
umm, yeah ... I could use one for sure. Might save some enclosures. Half of my 125B builds either have DC jacks colliding with PCBs or TR jacks colliding with lip on the back cover :-[
I know I'd get one with my next order!
I would greatly appreciate it, if you could share a template for this! I imagine, ordering this from oshpark will be very cheap and easy..
Yet another very awesome thing that makes me say: "Why didn't *I* think of that?"
Thats awesome and would definitely pick one up in your store
Super awesome. I love a good jig to make thing easier. This is fantastically simple.
Quote from: m-Kresol on July 13, 2018, 07:12:45 AM
The mouse nibbles on the edge of OSHPark PCBs might screw with the registration of the template on the enclosure edges, though.
Quote from: alanp on July 13, 2018, 06:56:07 PM
Yep. To prevent this from being a problem these are built from three individual non-panelized PCBs. It costs a bit more to do it this way but it gives each part a much nicer edge.
I didn't expect so many folks to be interested, let me see how many I have left and I'll get some more on the way if needed.
I'll definitely be getting one from you BuGG. Unfortunately, it just means that I'll have perfectly aligned holes at the wrong end.
Update: I cut up my spare label and filled the holes with PVA...
Quote from: EBK on July 12, 2018, 06:34:33 AM
+1 on this. I've used this same method and it definitely works. I haven't had any problems with the JB weld "plug" cracking or falling out. It seems to be nearly as tough as the original aluminum.
Quote from: lars on July 14, 2018, 08:52:52 AM
What do you guys use on the back side to hold the JB Weld in place while it dries? Tape?
Quote from: culturejam on July 14, 2018, 10:31:22 AM
Gaffer's tape is what I used. Also, I don't remember if I got this tip here or over at DIYSB, but slightly beveling the hole that you are about to plug on both sides (as if you are slightly countersinking) may give your JB Weld "coin" a bit more security. I wouldn't call it a necessary step though.
^^ Ah, thanks!
Just as with any other template, it is made for a specific thing. My question is what if there are components or other items that interfered with the jacks or power plug? It's all well and good for guts that have plenty of clearance but, what if that is not the case? Essentially, every design would have to be produced with that template in mind.
Quote from: Govmnt_Lacky on July 14, 2018, 02:32:20 PM
Yep, and that's why standardizing around a single set of hardware placements saves a ton of time and money in a production environment.
Quote from: culturejam on July 14, 2018, 05:11:09 PM
Gotcha. So this would only be viable for those who are comercial builders then. Now I understand.
Quote from: Govmnt_Lacky on July 14, 2018, 05:13:46 PM
I think hobbyists would get some use out of it, but it does sort of limit your options. If you like to build each pedal with a totally unique setup, templates are probably not ideal.
If it fits into your design parameters, it'll be a massive timesaver.
In all honesty, most of my pedals use the same template as far as in/out/power goes, with variation depending on what controls are necessary.
In this case if you're doing Bugg layouts its a no-brainer because he's settled on a repeatable 125B pattern so it covers the bulk of his builds. I suspect it would also apply to the new Aion stuff as well. I've never been a big 125 fan but have to admit, it lowers the stress level stuffing the enclosure and it's kinda cool having a consistent footprint on my board.
When I was still making Blue Dogs I had a lexan template that just draped over the 1590BB and you could just scribble sharpie marks on an enclosure when we got them back from the printer but I've been too lazy to duplicate the setup for my own stuff.
Okay, I put a few of the templates up on the site. Probably bad form to link it here, if you don't know where to find them shoot me a PM.
