Hey all,
I built a Total Recall and biased it per the revised instructions (pin 7 and 14/15 of the V571 for Gain 2). It works but...it just doesn't feel right. I can get self oscillation, but that's not until like max feedback. I only get one or two repeats until the feedback pot is at the halfway mark. Any thoughts?
On top of that, I feel like the repeats are very...abrupt? Is that normal? The only other analog delay I have to compare to is the Aqua Boy I built, and the repeats seem much more organic.
Thanks all1
Post your voltages of the compander (v571).
You should have -4.7 volts on pin 7 of V571 and -13 volts on pin14 & pin15.
Gain 1 and Gain 2 trimmers affect the repeats.
If everything looks right, check the resistors after the compander till the FBK pot (r12,r14,r17,r19,r21,r25,r26,r27,r32,r33).
Cheers,
Panos
Thanks for the assist! Pin 7 is reading -5.6, and pins 14 and 15 are reading -12.95.
Curious as to why pin 7 is running -1 v higher than normal...
Yeah thats a bit odd, despite that check resistor values of R9, R10, R11 and last R12, R13.
Resistor values are all correct for R9-R13. 68k for R9, R10, R11, 24k R12, 51k R13. This is weeeeird.
anyone else have any insight?
