Hi,
I was trying another simple flanger build, starting from the ultra flanger and decided to go with the electric mistress signal path to cut some extra noise.
I used the V3207 as the BBD and based much of this one on the design presented here:
https://www.diystompboxes.com/smfforum/index.php?topic=91981.0 (https://www.diystompboxes.com/smfforum/index.php?topic=91981.0)
As for the layout I started from the zombie chorus presented by Cozybuilder (thanks for sharing the layout btw) to build it inside a 1590LB.
So, there was some sanding involved...
I had to sand the base of the screws a little bit, so that the pots would be at an aesthetically pleasing position. Further to the middle it looked too strange, or it would feature only 3 knobs. But it's not a flanger if it only has 3 pots...
Another critical area were the jacks. They were much larger than they needed to be, so I sanded them a little bit. Here you have the final result:
(https://i.imgur.com/Il9pZLzl.jpg?1)
(https://i.imgur.com/x7kzdCrl.jpg)
(https://i.imgur.com/n9NTJDXl.jpg)
(https://i.imgur.com/fsc4kfyl.jpg)
(https://i.imgur.com/fzbkl1rl.jpg)
(https://i.imgur.com/CGv6Niwl.jpg)
I soldered the pots to one side, so that the board can go down as a lid, with the connection to the pots working as the hinge.
(https://i.imgur.com/BWjDpD8l.jpg)
(https://i.imgur.com/0wFHW2El.jpg)
(https://i.imgur.com/1GVKupil.jpg)
(https://i.imgur.com/3jhDiGnl.jpg)
So, are there some mod suggestions?
It can't do super jet sounds and it gets weird at higher speed settings. The Manual control was a good addition, because I can get some chorus sounds with the manual maxed and color at null.
There could be more color too, but I guess then I'm entering ultraflanger's noisy territory.
:o :o :o
It must be smaller....
Quote from: jimilee on April 23, 2019, 08:10:00 PM
What the serious f***
Unreal. Just unreal. :o
This is ridiculous is the best possible way.
Quote from: DLW on April 23, 2019, 10:52:17 PM
Totally agree. Dig it.
If there was ever a guitar pedal that I wanted to marry and have its adorable children with, it's this one.
Nice work. :o
This is getting out of hand. I think that I might have wept a little trying to cram a Schu-Tone board into a 1590A and it was roomy by these standards. I need to accept stuff like this and get past it :-)
Very impressive at both the stuffage and etching levels.
I feel completely, hopelessly inadequate.
Nice work.
Wow...just, Wow....
What in the goddamn...? That's gotta be approaching black hole levels of density! Seriously impressive work! I really dig the etching too!
What they said.
That is crazy build! Love it
I still have a hard time believing any of your tiny builds are real -- they are that good. ;D
(Are you also a watchmaker?)
Amazing work, as always!
Thank you!
here you have the schematic and layout, in case someone wants to give it a try
(https://i.imgur.com/5F7svV6h.png)
(https://i.imgur.com/QvyH4UYh.png)
(https://i.imgur.com/LsNXYpMh.png)
For the top layer I used some wires, so that I could go with a single sided board.
And here a short sample:
just had a panic attack
that's insane
you're crazy!
I LOVE it!
I have so much respect for you. This is totally inspiring as with all of your tiny little builds. Bravo.
Stunning. Impressive. Beautiful. Inspired and inspiring.
It's a piece of art. Really cool!
