Author Topic: Snarkdoodle WHRL clone video  (Read 2041 times)
chromesphere
  • Paul
    • Chromesphere
« on: January 26, 2011, 02:40:27 AM »
Hey,
Wanted a simple build, so built the Snarkdoodle. Just finished a quick demo video of the Snarkdoodle and the Big Muff Pi.  Hope you like it:
http://www.youtube.com/watch?v=amDDsiG8L_g
Paul
Pedal Parts Shop            Youtube
FuzzMonkey
  • Transistor Tickler
Re: Snarkdoodle WHRL clone video
« Reply #1 on: January 26, 2011, 02:48:44 AM »
Nice work.
chromesphere
  • Paul
    • Chromesphere
« Reply #2 on: January 26, 2011, 02:59:03 AM »
Oh, and heres some photos.  Inspired by some of the immaculate entrails of other peoples builds, i have also shown the guts of this pedal.  I really tried to keep my wiring neat with this one.  Still looks like a mess...!  :o
Also went for a 'polished silver' look.  Looks more sort of brushed silver, something different anyway...
*** Thanks FuzzMonkey!
[attachment deleted by admin]
« Last Edit: January 26, 2011, 03:02:20 AM by chromesphere »
« Reply #3 on: January 26, 2011, 08:31:20 AM »
Love the polished enclosure - did you just sand it for a while, or was there more work involved?
chromesphere
  • Paul
    • Chromesphere
« Reply #4 on: January 26, 2011, 04:26:22 PM »
Thanks Lincolnic.
I wet sanded up to, i think it was 1200 grit.  Then i used Brasso on it (i metal polish).  I put it on pretty thick and let it sit there for 10 mins approx before removing.  I found the Brasso gave it a bit of extra shine.  I used Brasso on it about 5 times.
Still couldnt get a 'Mirror Finish" though. I'm assuming the aluminium is low quality or something...just couldnt get it to shine anymore...turned out having more of a brushed finish.  Still looks good though!
The knobs are from Jaycar for any aussies out there reading.  They are expensive at 2 bucks each but they are the best quality knobs i've found (so far).
Paul.
  • Global Moderator
  • Jacob - SK, Canada
    • JMK PCBs
« Reply #5 on: January 26, 2011, 04:32:55 PM »
To ge mirror you have to get a lot higher with the sandpaper. I use:
120
240
400
800
1000
1200
1500
2000
2500
You have to spend a lot of time with the low grit paper the longer the better. I wet sand starting at 400. Use a power sander for the low grits if you can. 5 min with each value equals hours by hand.
chromesphere
  • Paul
    • Chromesphere
« Reply #6 on: January 26, 2011, 05:52:57 PM »
Wow, 2500....!!  Didnt know it existed lol.
You know, i think i'm going to get some,  pull the pedal part, and give it another crack!
Thanks for the tip!
Paul
  • Administrator
  • Brian
    • madbeanpedals
« Reply #7 on: January 26, 2011, 06:16:11 PM »
Yeah, for those high grits you should try an Auto Shop. They are likely to have them.
I use Brasso for polished finishes, too. But, I only do one pass cause I roll like that.
Very nice work, chromesphere! I humbly suggest getting rid of that white washer on your switch though. Go industrial to compliment the rest of the design!
  • Global Moderator
    • JMK PCBs
« Reply #8 on: January 26, 2011, 07:15:09 PM »
Yeah, I get my high grits at an auto shop.
I forgot to mention that I then use a buffing wheel attached to a drill press and some aluminum polish as well.
chromesphere
  • Paul
    • Chromesphere
« Reply #9 on: January 26, 2011, 10:04:25 PM »
Ahhh...one particular hardware store only had up to 1200-1400 grit...ok ill try an autoshop, thanks for the tip.
Good idea!  When i have a go at the finish again, i will get rid of the plastic ring...didnt think of that.
I'm imagining i wont need to Brasso so many times if im using higher grit paper too.
Paul
« Last Edit: January 26, 2011, 10:21:53 PM by chromesphere »
  • Josh
    • 1776 effects
« Reply #10 on: January 27, 2011, 09:30:53 AM »
do you just use a regular vibratory hand sander Jacob?
that's a lot of grit sizes!  guess you need to shop to not spend a fortune on sandpaper   :D
