Author Topic: State variable filter preamp?  (Read 4594 times)
garfo
  • Solder Ninja
  • Nuno
« on: August 09, 2013, 03:51:37 AM »
Has anyone one come arround with an Alembic/Wal type of filtering equalization???
« Last Edit: February 13, 2014, 08:04:44 AM by garfo »
Willybomb
    • RockStarGuitar
Re: Bass filter/eQ preamp
« Reply #1 on: September 11, 2013, 06:13:57 PM »
Dunno anything about that, but paulinthelab has a vero layout of the Yamaha ne-1 bass preamp pedal that I'm going to build shortly.  Personally I think Brian should do a pcb for it and call it the "Random Stranger"
RobA
    • Music Unfolding
« Reply #2 on: September 11, 2013, 07:06:57 PM »
Are you talking about onboard preamps or an amp preamp?
  • Jimi Lee
« Reply #3 on: September 11, 2013, 09:26:04 PM »
I'd totally build this just because of the name.
garfo
  • Solder Ninja
  • Nuno
« Reply #4 on: January 25, 2014, 01:15:45 PM »
Hi, sorry for the real late reply.It is an onboard filter based bass preamp as seen on Wal and Alembic basses.It consists of a Volume, a Blend, 2x Mid filter sweep plus boost(stacked) 1 for each pickup, and a treble boost.
So, I found a state variable filter project, and my idea would be having two of these where we could add an active blend control and each filter controls one pickup, both would have a master volume.Guys, is it doable?
http://www.musiker-board.de/attachments/f3-musik-instrumente-know-how//f75-e-gitarren-forum//f39-modifikation-technik-gitarrenbau-e-git//241993d1350756654-lemme-state-variable-filter-sounds-aufnahme-kleiner-test-state-variable-filter_diy-layout-neu.gif
« Last Edit: February 13, 2014, 07:53:25 AM by garfo »
thesameage
  • JR
Re: State variable filter preamp?
« Reply #5 on: October 21, 2016, 09:28:11 PM »
Has anyone built this?
Torgoslayer
  • Solder Ninja
« Reply #6 on: October 22, 2016, 12:43:39 AM »
Rullywow has a great pcb project for that called the Canned Yam.
thesameage
  • JR
« Reply #7 on: October 22, 2016, 09:05:47 AM »
I saw that. I'm thinking of building one. It has a high pass filter on it... wonder if it's possible to futz with the values to make it a low pass filter.
HamSandwich
  • Solder Ninja
« Reply #8 on: October 22, 2016, 10:04:54 AM »
If it's basic enough, you can replace the resistors with caps and caps with resistors.
