zombii board mounted knobs
Started by PLAINCLOTHESMAN, February 12, 2011, 04:56:35 PM
PLAINCLOTHESMAN
so i just built a zombii and its sounds amazing. im super excited about it, however i did the drilling for the board mounted knobs and they go in fine, but im having a hard time finding knobs small enough to fit. what does the original use? I tried some off my mxr, and one knob is always not fitting. did anyone else have this problem with the pcb mounted 9mm pots? ???
The original uses 3/4" mxr style. Those won't work with the madbean board. Remember that the madbean board isnt the same as the zvex board. Just cause the zvex works with 3/4" knobs doesn't mean yours will.
I used 1/2" plastic knobs. Metal ones will work also. If you can find 2/3" knobs those would work also.
