Author Topic: Harbinger One  (Read 1353 times)
aballen
Harbinger One
« on: September 21, 2013, 01:53:12 PM »
Just wanted to show off my harbinger one.  I need to add some graphics, but its been rocked, and boxed, and it sounds amazing.
First off the light sheild.  I found some rubber 3/4" chair leg tips at the hardware store and some reflective tape.  Combined they made a pretty good light shield.
The pedal work the first time I powered it up, all credit goes to Brians excellent pcb and documentation.
Now I was originally planning on using the four holes to "wire down" the shield, but I came up with a better idea, that worked out perfectly.  I went with a shallower box, and used a light plate to hold the light shield in place.  I drilled a 7/8" hole in the light plate and the light shield went right in.  It actually presses the light shield right up against the board too.  Also the added benefit was I could easily take the shield off while twiddling with the trimmer, which I did a lot of.
Here is the shield mounter in the plate
and here it is on the board/enclosure.
You cant tell from the picture, but I mounted the light shield to leave just a hair of a gap between the enclosure.  This way when I fasten the bottom plate on I know I'm pressing the light shield right against the pcb.
Needs graphics and a sound clip.  In the meantime let me just say its a great pedal once dialed in.  With chorus off and the vintage buffer on, it goes from a nice smooth vibrato to an energetic one.  Flip on the chorus, and it gets lusher and more warbly.  Flipping on the modern buffer really intensifies the effect to where I can get a really swishy and warbly sound our of it, with everything jacked up it sounds like a lush rotary.
I'll be in Dublin this week, so hopefully I have time when I get back home to do the graphics and a clip to enter this is the monthly contest.
Very rewarding build.
Diamond
  • Transistor Tickler
Re: Harbinger One
« Reply #1 on: September 22, 2013, 04:22:32 AM »
Wow, great build man! And thanks for the tips. I just ordered my Harbinger One PCB yesterday. I am really looking forward to finishing my own.
aballen
Re: Harbinger One
« Reply #2 on: September 22, 2013, 07:16:27 AM »
