Author Topic: Design and Development Board Tutorial (Prototyping)  (Read 19023 times)
  • Global Moderator
  • Jacob - SK, Canada
    • JMK PCBs
Re: Design and Development Board Tutorial (Prototyping)
« Reply #15 on: June 23, 2011, 04:38:16 PM »
You welcome.
I just use a pair of berhinger headphones.
bigmufffuzzwizz
  • Magic S.
    • Magic Pedals
« Reply #16 on: June 24, 2011, 12:53:42 PM »
at CultureJam
Can I ask what the cap on the speaker hookups is?
My guess is a power supply filtering cap to get clean DC voltage. Probably 100uf from 9v to GND.
Owner and operator of Magic Pedals Partner and production builder of Dunwich Amplification
add4
  • Solder Ninja
    • gypsy jazz band in belgium
« Reply #17 on: January 20, 2012, 08:02:19 AM »
i'm looking for a fast and easy way to hook up the pots to the breadboard, without soldering them
anyone has a good solution for that?
  • Global Moderator
    • JMK PCBs
« Reply #18 on: January 20, 2012, 09:35:46 AM »
Use PCB mount Pots. The have pins built in.
  • Josh
    • 1776 effects
« Reply #19 on: January 20, 2012, 11:08:48 AM »
You can use a trim pot as well.  Granted your stuck with a linear taper.
Josh
jeffaroo
  • Solder Ninja
  • Projects Inspired By Anheuser Busch
« Reply #20 on: December 18, 2012, 11:29:05 AM »
mount your pots to a small plate and solder short wires to them, then connect the wires to a terminal strip
now you can jump to the board off the terminal strip. My plate is about 12" long with all my hard-mounts on it. in/out/power switch/led/6 pots of different values   ;D
Not enough germaniums in this world to complete my wish list !
Bufferz
  • Transistor Tickler
    • TFX
« Reply #21 on: January 11, 2013, 01:13:36 PM »
Here what I am using:
I hear that pcb mount pots can work as well, though they may wear out the breadboard.
affiliations: TFX
danwelsh
    • Eliquid in Canada
« Reply #22 on: November 23, 2014, 09:58:43 AM »
Thanks Jacob.  One question.  Could a person be ablessed to add the testing rig probe to this?
  • Global Moderator
    • JMK PCBs
« Reply #23 on: November 23, 2014, 10:05:01 AM »
Yep.
The Testing Rig PCB could easily be incorporated into this sort of a setup easily. This would provide you with on board signal and headphone amp, which is usually helpful while prototyping late at night like I usually do. The benefit of course would be that you can also use it for testing finished PCBs, and then troubleshooting them with an audio probe.
However, I like having two separate setups. I prefer to use my testing rig with probe separate. You can use a simple wire to probe a circuit that's on your breadboard, and in fact, the output connection to the junction box functions just this way.
danwelsh
    • Eliquid in Canada
« Reply #24 on: November 25, 2014, 08:59:44 AM »
Yep.
Right on man. Thanks
Dan
