12.13 Etcher's Paradise update
Started by madbean, December 13, 2013, 02:45:05 PM
alparent
May I sugest backing everything up after.  ;)
I'm French.......sorry for my bad Englishhhhhhh.
EBRAddict
Cool. I just picked up a cheapo band saw to neatly cut multiple boards from a single etch.
alparent
I put a metal cutting blade on my bandsaw when cutting PCB. Finer tooths = neater cuts.
Is there an easy way to drill the boards? That's the only reason I haven't experimented with etching.
Quote from: jimilee on January 30, 2016, 12:54:32 AM
Yes, there is. But, it depends on how much you want to invest. The most efficient way is using a Dremel and the drill press attachment they make for it. That and some carbide bits are all you need to make very high quality DIY boards. When I do the tutorial, I will go over exactly which tools I use. I've used this stuff to make thousands of boards!
Strategy
Just grabbed some etcher's paradise Zip files. Thanks madbean!!!
