Will the new Fatpants fit in a 1590a?
Started by kurtsy, March 09, 2011, 06:35:48 PM
kurtsy
Does anyone know if the PCB is small enough to fit in a 1590a sized enclosure if you don't add the fat pot? I've seen some old ones in 1590a's, but I was wondering if the PCB grew to accommodate the new pot.
Thanks,
Aaron
Yes, it will fit. It is 1" wide, which means there will even be a little room left on the sides.
If you use 9mm pots, you can get both controls in there. Or, perhaps 12mm ones.
