Lowrider - Missing first octave down
Started by Pietrus, January 28, 2014, 07:33:08 AM
Pietrus
Hi guys,
i got some problem with my lowrider. I apologize for my english, it isn't my native language, if something isn't clear, please ask.
General description of the problem:
I just finished my lowrider and my clean, octave up, second octave down is working. I like the sound of this pedal, it's very nice :) But I got some trouble with my first octave down. If I turn everything else all the way down, and doct1 all the way up, I get just some very quiet noise. This noise doesn't depends on the input.
I found this is an interesting problem, because according the schematic, the second down octave is generated from the first down octave. So I don't get, how the second work, if the first doesn't.
Steps that I have taken to try to resolve the issue
I checked the pads, and if I found a questionable one, I heated it up, and soldered again.
I checked the pinout of  q2 and q3, because I use 2sk30, and it's pinout is different, than the PCB's. I twisted the pins to the correct configuration.
I checked the contacts between the parts and the pads, in case of the parts of first octave down (according to schematic.
List any substitutions you used for parts/values
Instead of 1n34 diode, I used OA1182 germanium diode.
I used 2sk30 fet for Q2 and Q3.
I omit c12 and used 1n for c10.
I would be very happy, if someone can give some advice, where should I search.
Thank you.
Try audio probing, following the first octave down path. I suspect a bad connection somewhere AFTER the first octave is split off from the octave generation, like a dry solder joint on a pot or something.
Pietrus
I found the missing octave :) I share the problem, I hope, it can help somebody.
I tried the audio probe, and when I toched the Doct1 pot's middle pin with the multimeter, I could hear some noise. This noise was different from the earlier, it was louder. So I found out, my potmeter was dead. I don' know how and why, but after desolder it, I couldn't measure any resistance between any pins of the potmeter. I will buy an other, and try it.
Thanks for the idea.  :)
garfo
Quote from: Pietrus on January 30, 2014, 08:14:46 AM
Hi Pietrus. Were you successful?
I'm having exactly the same problem with a Boss OC-2. Everything works except first Ocatve down.
