my pedal clicks through the amp
Started by MJL90, March 21, 2011, 04:30:04 PM
MJL90
When I turn on my Modtone delay and Vox wah the click of the switch can be heard through the amp, it's annoying as hell, anyway to fix this? Or is it because I'm using a solid state amp
jtn191
#1
you might want to look into electronic switching, something like Jack Deville's click-less bypass
alternately, I heard you could solder a 4M7 resistor from input to ground to get rid of it
MJL90
It's not as bad now that I moved the pedal to the last pedal
bigmufffuzzwizz
Quote from: MJL90 on March 22, 2011, 08:32:37 PM
Thats strange. Are you using a power supply?
mattpoole
i have a hardwire tuner that does the same thing. it is true bypass and i am thinking about trying to rewire it myself. if you resolve your problem please post the solution. thanks.
MJL90
Yeah it's true bypass, using a power supply but it also does it running off the 9v
thatirishsob
I have the same problem with my tuner if I have a boost pedal or some overdrive pedals on when I press the switch. As long as they are off it's silent.
MJL90
I opened it up to have a look, but being a reasonably cheap pedal, the board is impossible to take out =( I don't think it does it on a valve amp
