The Voltages Thread (Hopefully)
Started by RobA, August 27, 2014, 09:36:29 AM
RobA
I brought up the idea a bit ago of having a dedicated thread for known good voltages for the projects. It seemed at least some folks thought it might help, but then I got sidetracked and it went to the back of my mind. Anyway, I still think it could be a useful resource and I just happen to have to voltages for my Stage Fright (which by-the-way, I love) sitting at hand, so here goes.
Stage Fright:
Supply voltage in: 9.4
IC1: (TL074)
1   4.67
2   4.67
3   4.25
4   9.33
5   4.64
6   4.65
7   4.65
8   4.67
9   4.64
10   4.55
11   0
12   4.62
13   4.65
14   4.64
IC2: (TL062)
1   Moving (.69 to 8.7)
2   4.65
3   2.8 to 6.5 or so
4   0
5   4.69
6   4.68
7   3 to 6 range
8   9.35
IC3: (NJM13700D)
1   1.16 to 1.27
2   0.291
3   4.57
4   4.57
5   5.72
6   0.31
7   5.6 to 5.78
8   4.58
9   4.59
10   5.64 to 5.7
11   9.16
12   5.63 to 5.73
13   4.58
14   4.58
15   0.38
16   1.13 to 1.27
IC4:
1   1.12 to 1.3
2   0.286
3   4.61
4   4.61
5   5.72
6   0.3
7   5.61 to 5.78
8   4.58
9   4.56
10   5.66
11   9.15
12   5.58 to 5.69
13   4.58
14   4.58
15   0.317
16   1.14 to 1.28
IC5:
1   1.11 to 1.3
2   0.29
3   4.63
4   4.61
5   5.64
6   0.4
7   5.68 to 5.75
8   4.58
9   4.60
10   5.75
11   9.23
12   5.60 to 5.76
13   4.62
14   4.61
15   0.363
16   1.14 to 1.28
Q1:  (2N3904)
E   3.90 to 3.98
B   4.56
C   9.14
Q2: (2N5457)
G   0
S   1.184
D   3.90 to 3.98
Q3: (2N3906)
E    4.56
B   3.90 to 3.98
C   1.13 to 1.38
GermanCdn
Great idea.  And nice job starting with the build that is my white whale, I have successfully f'd up three stage frights with the fourth on the way (two were me trying to  make things "better", and one's possessed).
muddyfox
I'm feeling pretty good about my Doppelganger. It's Ian/AlanP's 2.1d board.
-all ICs TLxxxCN
-all LEDs light up the same intensity
-rates on 1 o'clock
-spans, color, blend maxed
-square, slow to the right
-antiphase, true up
-phase on (I think  ::) )
-one lfo (green LEDs light in unison, I suppose that's one lfo?)
Source: 9.33
IC1 (TL074):
1-3: 4.29
4: 8.59
5: 3.8-5.2
6: 3.7-4.6
7: 3.6-4.7
8: 2.7-6.8
9: 3.8-5.2
10: 3.27-5.5
11: 0
12: 3.16-5.63
13: 3.6-5.3
14: 2.1-7
IC2 (TL072)
1: 3.7-4.5
2: 3.7-4.9
3: 3.8-5.2
4: 0
5: 3.8-5.1
6: 3.8-5.2
7: 3.8-5.2
8: 8.6
IC3 (TL074)
1-3: 4.1
4: 8.1
5: 4.0
6: 4.1
7: 4.1
8: 4.1
9: 4.1
10: 4.0
11: 0
12: 4.1
13: 4.4
14: 4.1
IC4 (TL072)
1-2: 4.1
3: 3.3
4: 0
5: 4.1
6: 4.1
7: 4.1
8: 8.04
oldhousescott
Maybe a mod could sticky this so it gets more views and posts.
copachino
might be worth creating a google spreadsheet or something that is linked to a sticky?
muddyfox
Rob, what are the pots positions that yield those voltages? Everything dimed?
RobA
Quote from: GermanCdn on August 27, 2014, 09:45:56 AM
Maybe the new one will play nice and go together easily. If you don't mind telling, what were you working on to make it better? I've put the CV control connections in mine, but haven't gotten around to doing anything with it yet.
Quote from: muddyfox on August 29, 2014, 12:03:48 PM
It's been a bit since I took them and I can't remember where I had it set. If it's like I normally do, then it would either be with both at noon, or with "balls" at noon and "speed" at zero.
Mine also has the Univibe mod caps in there right now, but I doubt that'll change the voltage readings.
RobA
I've finished up my Harbinger build and took the measurements for the voltages, so here they are. A few notes, I've subbed for most of the transistors, BC550, BC517, and a FJN598J for the JFET. The oscillator pair are 2N5088 though. I've got it done with the filter board as I'm using an 18V brick to power it. The readings were taken with the Intensity all the way up and the gain trimmer in the middle. I don't actually know where the offset trimmer is because I've got a multi-turn trimmer in there and I can't see where it's at. ~ ==> oscillating.
Voltage in 17.48
Voltage at regulator output 14.69
Q1: BC550
E:   1.05
B:   1.44
C:   2.14
Q2: BC550
E:   1.55
B:   2.14
C:   4.33
Q3: BC550
E:   3.74
B:   4.33
C:   13.62
Q4: BC550
E:   5.16
B:   5.54
C:   17.5
Q5: BC550
E:   4.55
B:   5.15
C:   12.94
Q6: BC550
E:   5.15
B:   5.54
C:   17.49
Q7: BC550
E:   4.55
B:   5.15
C:   12.94
Q8: BC550
E:   5.13
B:   5.52
C:   17.49
Q9: BC550
E:   4.53
B:   5.13
C:   12.95
Q10: BC550
E:   6.48
B:   6.98
C:   17.48
Q11: 2N5088
E:   8.1 ~
B:   7 ~
C:   14.69
Q12: 2N5088
E:   7.54
B:   8.1 ~
C:   14.69
Q13: BC517 Dependent on trimmers
E:   4.5 ~
B:   8.5 - 11
C:   oscillating around 5
Q14 FJN598J
G:    9.4mV
S:    326mV
D:    17.49V
Cortexturizer
RobA
I took the readings on my Naughty Fish to put up in another thread, so I figured I should drop them in here.
Mine's the 2014 version. I don't think that'll make a difference.
Pots are both at 12:00. Toggles are set to LP, Down, Hi
The input voltage is at 9.25V
IC1:
   1   0V
   2   0V
   3   0V
   4   -8.23V
   5   0V
   6   0V
   7   0V
   8   8.66V
IC2:
   1   ~80mV drifting
   2   22mV
   3   22mV
   4   -8.25V
   5   3.44V
   6   2.57V
   7   6.48V
   8   8.66V
IC3:
   1   0V
   2   0V
   3   0V
   4   -8.25V
   5   0V
   6   0V
   7   0V
   8   8.66V
IC4:
   1   1.37V
   2   4.62V
   3   0V
   4   -3.88V
   5   -8.24V
   6   2.55V
   7   1.41V
   8   8.66V
Vactrol 1:
   1   6.48V
   2   4.93V
   Resistor side both pins at 0V
Vactrol 2:
   1   6.48V
   2   4.93V
If a voltage read less than 1mV, I put it at zero.
Pork Chop Suey Cider
Voltages:
Q1 2N7000
G 6.8v
S 8.2v
D 9.1v
Q2 2N2484
C 4.1v
B 1.2v
E 0.6v
Q3 2N2484
C 4.8v
B 2.2v
E 1.6v
Q4 2N2484
C 4.2v
B 4.8v
E 9.1v
Q5 2N2484
C 2.2v
B 1.2v
E 0.6v
Q6 2N2484
C 4.8v
B 2.2v
E 1.6v
Q7 2N2484
C 9.1v
B 4.8v
E 4.2v
IC1 LF353P
1 4.5v
2 4.5v
3 4.5v
4 0v
5 4.5v
6 4.5v
7 4.5v
8 9.1v
IC2 LM388P
1 4.5v
2 4.5v
3 4.5v
4 0v
5 4.5v
6 4.5v
7 4.5v
8 9.1v
RobA
And since I'm on autowahs, here's the voltages for my Autobahn.
All knobs at 12:00
Vin = 9.22V
Regulator:
   Vout   5.04V
   Gnd   0V
   Vin   8.46V
Q1
   G   3.85V
   S   4.40V
   D   8.55V
Q2
   E   0.287V
   B   0.35V
   C   5.04V
Q3
   E   1.68V
   B   0.287V
   C   5.04V
IC1:
   1   4.23V      14   4.23V
   2   4.23V      13   4.23V
   3   4.22V      12   4.23V
   4   8.56V      11   0V
   5   4.23V      10   4.23V
   6   4.23V      9   4.23V
   7   0.465V    8   4.11V
IC2:
   1   1.68V         16   1.68V
   2   151mV (unstable)   15   160mV (unstable)
   3   4.23V         14   4.23V
   4   4.23V         13   4.23V
   5   5.42V         12   5.42V
   6   0V              11   8.56V
   7   5.42V         10   5.42V
   8   4.23V         9   4.23V
Third Eye Pedals Muff Gun
Voltages:
Q1
C 4.2v
B 0.8v
E 0.2v
Q2
C 4.1v
B 0.6v
E 0.0v
Q3
C 4.6v
B 0.5v
E 0.1v
Q4
C 4.6v
B 0.7v
E 0.1v
Q5
C 5.8v
B 1.5v
E 1.0v
Grind Customs FX TSM680 MK2
Voltages:
Q1
C 3.9v
B 0.6v
E 0.0v
Q2
C 5.6v
B 0.5v
E 0.0v
Q3
C 3.7v
B 0.6v
E 0.0v
Q4
C 5.2v
B 1.7v
E 1.1v
