Cool PCB rework
Started by pickdropper, November 12, 2014, 10:41:32 AM
I've seen some cool PCB reworks, but this is a bit beyond what I am used to:
https://home.comcast.net/~rburn/PCB-rework/
The dremel work is pretty impressive.  I'd be curious to see how well this holds up over time.
 :o far out! What a save! That burned pcb looked totally shot!
Shrtyska9
Thats pretty amazing stuff! I'm not sure I would have gone through all of that trouble of patching it when he had the art to etch the entire board. Certainly makes for a great story and some real street cred.
Richard
A small transfer punch followed by a chasing hammer and you can set those eyelets perfectly.
Mind boggling, incredible challenge, really couldn't imagine better,  i break a major sweat if a pad lifts... have to keep this is mind!
Thanks Dave!
I thought the solder wick as a bridge was clever as well.
pretty cool, should work fine.  lots of patience on this one
I forget how many damaged traces and pads were allowed for mil spec repairs, it might have been 2-3 in a square inch or something like that.  Commercial stuff was more forgiving.
I think we used to scrape out any charred material and then fill with epoxy, then there was copper foil that would be cut an pasted in, much the same as here, only with wire bridges.
My favorite ones to do were multi layer pcbs with bad via connections.  Didn't happen often but super challenging.
That was crazy awesome.
You, sir, are entirely out of your mind. What an awesome recovery. Class act all the way through.
Quote from: gordo on November 12, 2014, 03:16:09 PM
Just to be clear, that isn't me.  That is somebody who clearly has much more free time than I do.   ;D
chuckbuick
I like a good PCB challenge, too.  But I would've tapped out somewhere between the 2nd and 3rd pics.  Awesome work, though.
