Author Topic: Collosalus 2015 board error  (Read 1373 times)
  • Administrator
  • Brian
    • madbeanpedals
« on: February 10, 2015, 09:40:02 AM »
A customer sent me this picture of his Collosalus 2015 board. It appears that on his board there is a small trace bridge from C22 to ground which should not be the case. This is a manufacturing error as it most definitely is not in the design files I sent. Please see the pic below which shows the bridge inside the white circle.
I have spot checked some of the boards I have on hand and have not found another one like it, but I will be doing a continuity check on all the remaining boards to be sure.
So, I advise everyone who has received a board so far to inspect this area carefully. If you do see a bridge to the ground plane, it can be removed with either a razor or Xacto knife. Just cut the bridge between the pad and ground plane with a few controlled slices. If you have a continuity checker, please ensure that there is no connection to ground after you cut.
This might be an isolated incident, or not. I will update this thread when I finish inspecting the remaining boards. My apologies for the error.
BTW: Look at how tight that soldering job is! Impressive.
  • John - Wakefield, UK
    • Juan's Gnomepage
Re: Collosalus 2015 board error
« Reply #1 on: February 10, 2015, 04:02:14 PM »
That is some seriously lovely soldering :o
JuansoloFX Stompage - DIY effects library & stuff
(NOT commercial)
“I excite very large doom for days” - playpunk
eldzsi
  • Solder Ninja
  • Gabor - pedalhealer from Hungary
    • pedalhealer.com
« Reply #2 on: February 10, 2015, 05:00:52 PM »
This is the Ambulance pedal. Check the Build report.
« Last Edit: February 10, 2015, 05:03:24 PM by eldzsi »
www.pedalhealer.com
instagram: pedalhealer_dot_com
