Another rissole issue
Started by Luke51411, May 13, 2015, 10:19:40 PM
Luke51411
Quote from: jimilee on May 16, 2015, 02:38:41 AM
Quote from: Luke51411 on May 15, 2015, 02:28:25 AM
Duh... Thanks, did you get yours working?
That was it! I disconnected the effect loop and it fired right up! Du huh, I knew it was something simple and stupid that I did. Now I gotta figure out how those damn jacks are wired internally. I really appreciate your help sir, this thing is killer.
Cool man! Glad you got it going. It's a really unique sound with a bit of a learning curve. I'll be excited to get all the jacks wired up and try the effects loop and expression outs.
Good stuff! A high impedance expression pedal is very useful with some of this Lovetone stuff (I use a high impedance volume pedal, plug the volume pedal Output jack into the effect's Expression jack.)
I expect build reports for these rissoles :)
Luke51411
Quote from: alanp on May 16, 2015, 04:15:16 AM
Definitely a build report coming, might be a bit though, I'm trying something I haven't done before for the enclosure
I just gotta figure out the link it's for these jacks, I haven't found it yet.
Luke51411
Quote from: jimilee on May 16, 2015, 12:52:40 PM
Can you use a multimeter with a patch cable plugged in to determine which contacts do what?
Quote from: Luke51411 on May 16, 2015, 12:57:59 PM
Yeah well there's always that.
The enclosure is drilled, should be next week. I'm pretty excited about it too.
