Author Topic: Etcher's Paradise - Release Announcements  (Read 14066 times)
Matmosphere
  • Matthew
Re: Etcher's Paradise - Release Announcements
« Reply #15 on: July 28, 2016, 06:43:04 AM »
Isn't the extra stage at the front of the circuit?
Huh, so it is. I had just been reading r.g. Keen's easy mods page about putting a big muff tone control right befor the volume control on a circuit so I figured that's where it was on a muff. I haven't look a a Muff schematic for ages.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #16 on: July 28, 2016, 02:55:16 PM »
It's the buffer that is always present in the G2 design. There is a separate bypass buffer which is the one not included on this project.
EBRAddict
  • Solder Ninja
  • Strictly bush league
« Reply #17 on: July 28, 2016, 07:54:29 PM »
The two buffer sections combined with the first BMP stage form a bandpass filter. I forget the exact 3dB down points but it was around 80Hz and 1kHz. I replaced the first three stages with an equivalent opamp-based MFB filter with gain 10 and couldn't tell the difference.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #18 on: November 06, 2016, 04:50:09 PM »
Trumpkin
- Based on the Ibanez SD-9
  • Administrator
  • Brian
    • madbeanpedals
« Reply #19 on: November 07, 2016, 08:22:05 AM »
EgoDriver
- Based on the Fulltone OCD
peterc
  • Solder Ninja
  • Peter
    • Bizzar Audio
« Reply #20 on: November 07, 2016, 02:32:59 PM »
Luvverly stuff....
Affiliation: bizzaraudio.com
  • Administrator
  • Brian
    • madbeanpedals
« Reply #21 on: December 12, 2016, 08:48:46 AM »
FlimFlam
- Based on the EHX Double Tracker
This is a slapback echo which I've set up for 9-12v DC supply instead of 18v like the original.
artstomp
  • Stompbox Star
FlimFlam 3008
« Reply #22 on: December 12, 2016, 10:30:54 PM »
..will the FlimFlam still be useable as intended if i use MN3008...what modifications should be done to at least extend the delay time....i'll be using my 2 MN3005s for a total recall build and still have an MN3008 collecting dust on my drawer...tnx
« Last Edit: December 12, 2016, 10:43:50 PM by artstomp »
  • Administrator
  • Brian
    • madbeanpedals
« Reply #23 on: May 18, 2017, 08:11:47 AM »
Total Recall
- Based on the EHX DMM
This is the same project as the manufactured board except for 1) it goes in a 1790NS and 2) does not include the BBD expansion board (so 2x MN3005 only)
1790NS: https://www.pedalpartsplus.com/product-p/1700.htm
  • Mike
    • Custohm Electronics
« Reply #24 on: May 18, 2017, 09:39:38 AM »
Total Recall
Holy Smokes! this is gonna be awesome!
stringsthings
« Reply #25 on: May 18, 2017, 01:58:10 PM »
Nice!  Gotta save up for some MN3005's.
All You Need Is Love
  • Mike
« Reply #26 on: May 18, 2017, 07:39:18 PM »
Paul has the Xivive ones and I think they end up being cheaper than $20 USD.
storyboardist
  • Stompbox Star
  • David - Woodstock, GA
    • Perf & PCB Layouts
« Reply #27 on: May 19, 2017, 07:08:19 AM »
Total Recall
Holy crap, I think that's the biggest etchable board for an effect I've ever seen.
Guy behind Effects Layouts
  • Administrator
  • Brian
    • madbeanpedals
« Reply #28 on: May 19, 2017, 07:16:12 AM »
Then you should check out the layout (not mine) for the Ring Stinger :)
  • Mike
« Reply #29 on: May 19, 2017, 07:18:01 AM »
Yeah that thing is MASSIVE! plus there are 2 add on boards also...
