Author Topic: Gravity Wave (Verified)  (Read 17385 times)
  • skilled electronics ninja master
  • Cody - Fresno CA USA
    • My Blog
« on: February 22, 2016, 04:18:55 AM »
This is a fun pedal and will get boxed up for sure.
I was battling with another build of mine and decided to populate this to clear the mind a bit and next thing I knew it, I was firing it up. Played with it for about 45-hour and it was fun. From subtle to extreme chorus effect.
I also took my voltages to share.
Powersource: 9.1v
IC1:
1 4.3v
2 4.3v
3 3.9v
4 0
5 4.3v
6 4.3v
7 4.3v
8 8.7v
IC2:
1 4.9v
2 2.4v
3 0
4 0
5 2.7v
6 2.4v
7 0.8v
8 0.8v
9 2.4v
10 2.4v
11 2.4v
12 2.4v
13 2.4v
14 2.4v
15 2.4v
16 2.4v
IC3:
1 Varied
2 4.2v
3 Varied
4 8.7v
5 Varied
6 Varied
7 Varied
9 Varied
10 4.3v
11 0
12 4.3v
13 4.3v
14 Varied
IC4:
1 4.3v
2 4.3v
3 4.3v
4 0
5 4.3v
6 4.3v
7 4.3v
8 8.7
Edit: Fixed wrong voltages
« Last Edit: February 23, 2016, 02:46:27 AM by selfdestroyer »
Alex
  • Diode Destroyer
Re: Gravity Wave (Verified)
« Reply #1 on: February 22, 2016, 06:32:10 AM »
Hi Cody.
Is your Dimension pot working properly?
Some people built it on vero and had some problems:
http://tagboardeffects.blogspot.fr/2016/02/madbean-gravity-wave-earthquaker.html
Alex
  • Diode Destroyer
« Reply #2 on: February 22, 2016, 06:44:04 AM »
There's a writing mistake in you IC3 voltages.
14 pins and Pin 11 should be 0.
  • Jimi Lee
« Reply #3 on: February 22, 2016, 09:47:00 AM »
Well that's cool.
alparent
  • Stompbox Star
  • Alain in Gatineau, Québec Canada
« Reply #4 on: February 22, 2016, 10:03:57 AM »
That's good news.
Glad others are also verifying these great projects.
I'm French.......sorry for my bad Englishhhhhhh.
    • My Blog
« Reply #5 on: February 22, 2016, 11:16:53 AM »
Hi Cody.
Thats weird, I am definitely not getting any motor boating on the Dim pot. I will hook it up again tonight and play around with it. To be honest, I just watched the PGS video and I was able to achieve some of the sounds right off the bat so I called it good.
I checked my notes this morning and that was no misprint. I will trace it out tonight and see if it is in fact wrong.
Thanks for the info.
    • My Blog
« Reply #6 on: February 22, 2016, 11:23:24 AM »
I will add this for reference:
Rate: Sets the speed of the LFO. The miniature LED will show the tempo even in bypass mode.
Shape: From soft triangle through hard square wave.
Dimension: Adds a slight slap-back at low levels, reverb-like ambiance at mid levels and an echo-resonance at max.
Intensity: How much the LFO modulates the delay time.
Animate: How far the pitch shifted signal swings, lower levels equals a tighter and more focused shift à la traditional chorus. As you increase the control a more wild and animated pitch shift begins to emerge.
Depth: How much modulated signal is blended in with the dry signal.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #7 on: February 22, 2016, 07:17:38 PM »
As mentioned before, pin11 of IC3 should definitely be 0v. It's connected to the ground plane.
Thanks for the update on verification :)
    • My Blog
« Reply #8 on: February 23, 2016, 02:44:51 AM »
ok, I rechecked my voltages and I definitely have 0v on pin 11 of IC3. I just wrote it down wrong. LOL
The dimension pot will oscillate just over 50% like a feedback pot on a delay pedal. Some tweaking might be in order.
This thing sounds great and will be boxed soon.
  • Jimi Lee
« Reply #9 on: February 23, 2016, 10:08:04 AM »
Why is this not in the store??? I need to have one.
alparent
  • Stompbox Star
« Reply #10 on: February 23, 2016, 10:31:33 AM »
There is enought etchers here to make you one. Just ask and make an arrangement.
I need to etch more boards (now that Brian added some projects) I could whip one up for you. (If you're not in a big rush.)
« Last Edit: February 23, 2016, 11:04:28 AM by alparent »
  • Jimi Lee
« Reply #11 on: February 23, 2016, 11:41:21 AM »
That would be lovely, thank you. No rush. I'd  learn if I didn't have to drill the boards.
Loe
  • Transistor Tickler
« Reply #12 on: February 23, 2016, 12:08:39 PM »
I feel the same, Jimilee. I love etching my own boards but the drilling makes me want to tear my hair out. I just showed my girlfriend how to do it. Let's see how many she does for me before she realizes how tedious it is.  ;D
alparent
  • Stompbox Star
« Reply #13 on: February 23, 2016, 12:21:38 PM »
What are you using? With the right tools......it takes the time it takes......but it's not that bad.
dan.schumaker
  • Schu-Tone
    • Schu-Tone
« Reply #14 on: February 24, 2016, 09:33:56 AM »
I feel the opposite.  I've never been able to get a good etch, but after getting a dremel drill press, drilling holes is no issue for me.
