Gravity Wave (Verified)
Started by selfdestroyer, February 22, 2016, 02:18:55 AM
This is a fun pedal and will get boxed up for sure.
I was battling with another build of mine and decided to populate this to clear the mind a bit and next thing I knew it, I was firing it up. Played with it for about 45-hour and it was fun. From subtle to extreme chorus effect.
I also took my voltages to share.
Powersource: 9.1v
IC1:
1 4.3v
2 4.3v
3 3.9v
4 0
5 4.3v
6 4.3v
7 4.3v
8 8.7v
IC2:
1 4.9v
2 2.4v
3 0
4 0
5 2.7v
6 2.4v
7 0.8v
8 0.8v
9 2.4v
10 2.4v
11 2.4v
12 2.4v
13 2.4v
14 2.4v
15 2.4v
16 2.4v
IC3:
1 Varied
2 4.2v
3 Varied
4 8.7v
5 Varied
6 Varied
7 Varied
9 Varied
10 4.3v
11 0
12 4.3v
13 4.3v
14 Varied
IC4:
1 4.3v
2 4.3v
3 4.3v
4 0
5 4.3v
6 4.3v
7 4.3v
8 8.7
Edit: Fixed wrong voltages
Alex
Hi Cody.
Is your Dimension pot working properly?
Some people built it on vero and had some problems:
http://tagboardeffects.blogspot.fr/2016/02/madbean-gravity-wave-earthquaker.html
Alex
There's a writing mistake in you IC3 voltages.
14 pins and Pin 11 should be 0.
Well that's cool.
alparent
That's good news.
Glad others are also verifying these great projects.
I'm French.......sorry for my bad Englishhhhhhh.
Quote from: albru80 on February 22, 2016, 04:32:10 AM
Hi Cody.
Thats weird, I am definitely not getting any motor boating on the Dim pot. I will hook it up again tonight and play around with it. To be honest, I just watched the PGS video and I was able to achieve some of the sounds right off the bat so I called it good.
Quote from: albru80 on February 22, 2016, 04:44:04 AM
I checked my notes this morning and that was no misprint. I will trace it out tonight and see if it is in fact wrong.
Thanks for the info.
I will add this for reference:
Rate: Sets the speed of the LFO. The miniature LED will show the tempo even in bypass mode.
Shape: From soft triangle through hard square wave.
Dimension: Adds a slight slap-back at low levels, reverb-like ambiance at mid levels and an echo-resonance at max.
Intensity: How much the LFO modulates the delay time.
Animate: How far the pitch shifted signal swings, lower levels equals a tighter and more focused shift à la traditional chorus. As you increase the control a more wild and animated pitch shift begins to emerge.
Depth: How much modulated signal is blended in with the dry signal.
As mentioned before, pin11 of IC3 should definitely be 0v. It's connected to the ground plane.
Thanks for the update on verification :)
Quote from: madbean on February 22, 2016, 05:17:38 PM
ok, I rechecked my voltages and I definitely have 0v on pin 11 of IC3. I just wrote it down wrong. LOL
The dimension pot will oscillate just over 50% like a feedback pot on a delay pedal. Some tweaking might be in order.
This thing sounds great and will be boxed soon.
Why is this not in the store??? I need to have one.
alparent
#10
There is enought etchers here to make you one. Just ask and make an arrangement.
I need to etch more boards (now that Brian added some projects) I could whip one up for you. (If you're not in a big rush.)
Quote from: alparent on February 23, 2016, 08:31:33 AM
That would be lovely, thank you. No rush. I'd  learn if I didn't have to drill the boards.
gül
I feel the same, Jimilee. I love etching my own boards but the drilling makes me want to tear my hair out. I just showed my girlfriend how to do it. Let's see how many she does for me before she realizes how tedious it is.  ;D
alparent
What are you using? With the right tools......it takes the time it takes......but it's not that bad.
dan.schumaker
Quote from: aishabag on February 23, 2016, 10:08:39 AM
I feel the opposite.  I've never been able to get a good etch, but after getting a dremel drill press, drilling holes is no issue for me.
