Author Topic: EHX Nerds - Octave Multiplexer Mod help  (Read 2102 times)
the3secondrule
  • Jeremy - head solder monkey - tinnitus industries
    • My Band - Force Fields
« on: March 18, 2016, 02:39:34 AM »
Hey guys,
I have one of the reissue (XO) octave multiplexers that I'm looking to get a little more volume out of. Doesn't need to be a massive volume bump, but with the mix at 50% it's slightly below unity.
Am I able to tweak some values to get a little more juice out of the circuit, or am I best to just whack an LPB on the output and be done with it?
Schematic here:
Re: EHX Nerds - Octave Multiplexer Mod help
« Reply #1 on: March 18, 2016, 07:37:17 AM »
That schematic doesn't match up to the XO version, the design was changed up a bit.
For ease i'd suggest you just stick on an output boost, you could try lowering the blend pot value but you might end up with getting bleed at either end of the pot.
the3secondrule
« Reply #2 on: March 21, 2016, 04:08:46 PM »
Sweet. Have lowered the blend to 50k, although I suspect I'll need to go lower. I don't mind a bit of bleed through as I don't see myself using it either 100% wet or dry.
Will drop it down to 10 or 25k and if that doesn't do it I'll add a booster
Kristopher
  • Diode Destroyer
« Reply #3 on: August 21, 2017, 08:12:21 PM »
Hey the3secondrule,
I know it's been over a year. But...
Did you have any luck with the volume drop issue when you switched the Blend Pot. Was 50k enough?
Any help would be appreciated. The multiplexer is a blast. But the volume drop is such a buzz kill when used live.
Thanks,
Kristopher.
