Ye Olde fr4 Cuttin' Blues
Started by playpunk, March 22, 2016, 07:13:05 AM
playpunk
How do you guys cut this evil crap? I've destroyed one sheet trying to figure it out.... Need help!
"my legend grows" - playpunk
If it is similar to the material the vero board i've used then I would suggest scoring it on both sides with a very sharp knife then breaking it. I also cut it with a hack saw, but once again it takes a sharp blade.
Quote from: Matmosphere on March 22, 2016, 07:18:16 AM
Yuo. Score BOTH sides. This is very important.
pryde
Dremel carbon cutoff wheel. Then a little light sanding to clean up the edge
Sent from my SM-G920P using Tapatalk
galaxiex
I use a table saw. Fine tooth carbide blade.
The nice thing about scoring is that there is no dust, the fist from that stuff is really bad for your lungs. Only works four straight cuts though.
blearyeyes
Do you need to wear a particular breathing protection if your using a power tool to cut the FR4?
I would say a dust mask and eye protection would be ideal. I remember cutting vero in my early days in the dust was awful.
rmfroyd
Try a tin snips, I have had good luck with those.  No dust.
Sent from my SM-G920V using Tapatalk
galaxiex
Quote from: blearyeyes on March 22, 2016, 12:36:50 PM
Yeah, sorry, I should have mentioned that I have a vacuum dust collection system. Tho I still wear a mask and eye protection.
A particulate mask at very least, or better yet, a respirator type mask N95 or better.
