tin or drill first?
Started by Orbis_Ignis, March 29, 2016, 11:19:47 PM
Orbis_Ignis
Do you guys tin your board first or do you drill the holes first? Never done this before so don't know which way is better
I, most of the time, drill then remove the toner. I typically don't LT my boards but if I did I guess it would be after I drill.
Drill, remove the etch resist then a few mist coats of lacquer.
blearyeyes
Quote from: davent on March 30, 2016, 12:41:35 AM
That makes sense, a little lacquer to stop corrosion then you can save your tinning supplies for two tone enclosure etches.
Does the tinning process add to the solder adhering to the pads or just corrosion prevention?
Never done this before either. Sorry for jumping in on your post...
Orbis_Ignis
Quote from: blearyeyes on March 30, 2016, 12:50:29 AM
No worries. All good info and great questions. Never thought of the laquer.
