Turnabout- Verified
Started by playpunk, April 11, 2016, 05:05:49 AM
playpunk
I'm in a rut as far as building goes. My last 3 projects have not worked, and it is ticking me off.
Most recently, my turnabout from ep has no sound.
My voltages are goofy- fluctuating on pin 1 between -.5 and .6.
Audio probing gets me clean audio through gain pot but nothin after.
Here are some pictures
"my legend grows" - playpunk
Droogie
The values that are visible appear to be correct resistor-wise; orientation of electros also good. Might check film cap values. Can't see the pot values well, but is Hair B25k as in the build doc. Looks like it might be B5k? Otherwise reflow and check very carefully for bridges—i.e., the usual stuff. Hope you get it working!
blearyeyes
So, you're getting audio at pin 3 of the gain pot and NO audio at pin 6 of the IC?
Check C5 and R6 for values continuity and solder bridges.
playpunk
Yeah. I will check those later
blearyeyes
#4
I hope you can get this verified cause I want to build one. Looks like a good "first etch" project.
Boba7
Yeah some solder joints look quite suspicious to me... Could be bridges (even the tiniest...), bad soldering, etc.
Hope you get it working! I'm quite tempted to build one too :)
playpunk
Ugh. That pot is a 5kb, and I am going to check the rest of the values tonight. And reflow. My solder ninja skills are not good enough for etched boards, I guess. I got so used to the nice solder mask
Boba7
On your pictures, it looks like there is a solder bridge between pin1 of the IC and ground. Also the drain of Q1 might not be very well connected to the circuit. And did you buy the 2N7000 from Tayda? I recently had problems with the 2N7000s I received from them.
blearyeyes
Quote from: playpunk on April 12, 2016, 05:01:00 AM
I'm right there too. Really a different style of soldering.
Boba7
I can confirm all the 2n7000 I received from Tayda recently are faulty. Maybe that's your problem.
playpunk
 Could be but I got those a while ágo and I think the others are ok. Gonna get back after this tomorrow
playpunk
Hey, just got back after this. It's working now- makes me think my testing rig is the problem!
