8-Ball Stupidity
Started by pryonisys, May 03, 2016, 06:22:47 AM
pryonisys
This really isn't a question, I just want to show off the stupid mistake I made when putting together my 8-Ball pedal.
Before anything else let me say that the pedal works great (not boxed yet but it sounds really good).  I was putting all the components in the board last night in the short time I have every week to work on these projects.  As I neared the end of my time blocked out for projects I just had to put in the switch and the pots.  I put the switch in first then realized my stupid stupid mistake when I went to put the first pot in the board.
As it currently stands it is going to be really hard to use the switch haha.
BrianS
Have I done that? Uh.... Yes I believe so.  It will come out but just be careful when you desolder it so you don't lift the pads. I find getting the switches off the board a lot easier than most other components. You have room to get the solder sucker in there.
I just disassembled a switch and desoldering the lugs one at at time, it was just easier, of course the switch was destroyed but the board wasn't harmed.
I did that with four rotary switches on a meatball build once. Wound up throwing the board away.
Quote from: alanp on May 03, 2016, 10:49:02 AM
I always remember that story every time I build something with rotary switches. lol
I have done this on one of my first Multiplex builds.. Its one of those things I think you do once and you ALWAYS remember after that point. lol
I feel your pain.
EBRAddict
I woke up one Saturday morning at 5 a.m. to finish up an Improbability Drive with six pots and two toggles. Got through soldering in the controls, went to the gym, came home, drilled the box, went to put in the board and was like WTF? Spent two hours gently removing the pots and switches.
Anymore I stay away from the soldering iron when sleepy.
icecycle66
I don't see a problem.
You just made it an easy access internal switch.
add4
be a booteek pedal builder and call it a feature?
pryonisys
I love so many of these responses.
Thanks everyone I feel better to know I'm not alone in some silly mistakes.
pryonisys
Got the switch back out and put in properly, the effect still works great.
Not going to box it until I have a second effect done so they can be boxed together.
Thanks everyone.
BrianS
Quote from: pryonisys on May 04, 2016, 08:47:30 AM
Chalk it up to a learning experience. Not only is your effect working but you didn't burn up your board getting the switch out. That's a two for one. Taking your time is probably an understated trait for this hobby.  I've done some really dumb things by getting in hurry. Congrats on getting it working.
