What's the noise?
Started by darrenw6000, September 03, 2016, 12:30:47 PM
darrenw6000
If you build an effect and it works but then when you put it in an enclosure you get a high pitch whine/whistle (gets worse as you crank the knobs) and also does it on battery power, what causes this?
Power supply? What effect?
darrenw6000
This was a while back. It happened on a tube screamer and big muff build.  What exactly is positive feedback if you could please explain.
JackSkellington
I got a sort of this noise, if I understand, with a TS808. Is that like a theramin high pitch? :o
Anyway, I had to move a bit the wires of the gain pot. I think getting far from the jacks.
Beware the ground wires, too.
What is your off board wiring?
with high gain circuits like this, it can be a problem of wire placement indeed. You could also try using shielded wiring for in and output.
darrenw6000
Ok thanks will keep that in mind
