Deadringer Jr. - Verified
Started by Ralfg, December 18, 2016, 06:02:11 AM
Ralfg
Finally got around to building this and it is verified.  I didn't have a right angle pcb mount 20KW, so I used a solder lug one, and I think I might just use solder lug pots on etched pcbs from now on.  I accidentally damaged the connection of lugs 2 and 3 on the drive pot so I had to make an extra connection with a jumper.  I think the nice thing about using solder lug pots on these is you have a bit more leeway to move the pots around after the fact, where with the right angle pots you can easily lift the copper right off the board.
Sounds great I'll have to box it up soon.  Ignore the extra little wire piece near c3.  To lazy to take another picture ;)  Thanks for the layout.
