Author Topic: turnabout clipping diodes glowing on and off with out anything wired  (Read 727 times)
Obie bong kanobie
  • Diode Destroyer
opamp voltages are all at half voltage, as expected  but as I touch the PCB it starts to glow on and off, I've built tons that work but I have two of them now doing this(all turnabouts)      the only mod I've done was resistor 8 on a switch (470 ohm and 1.8k)  wanted to see if it would have the same effect as the OCD hp lp switch as its basically the same idea, figured it was worth a try lol
« Last Edit: January 04, 2017, 10:45:28 PM by Obie bong kanobie »
Ralfg
  • Solder Ninja
  • Ralf
Re: turnabout clipping diodes glowing on and off with out anything wired
« Reply #1 on: January 11, 2017, 10:23:09 PM »
I've seen this with some really high gain circuits.  I think jiggling things and touching things might send some signal through it and you see the LEDs light up.  I built one once where the LED were glowing super bight until I hooked everything up (ground was the key) and then it worked great.  Are you having problems with the circuit or just expressing concern?
Obie bong kanobie
  • Diode Destroyer
« Reply #2 on: January 15, 2017, 08:04:15 PM »
ok ill try that out
Obie bong kanobie
  • Diode Destroyer
« Reply #3 on: January 16, 2017, 06:26:22 PM »
ok ive wired it all up in the enclosure and its the same thing, it only happens once i place in the opamp but both leds light up on and off as i touch it or move the board/wiring
devilsnight
  • Transistor Tickler
« Reply #4 on: February 11, 2017, 01:20:55 AM »
This happens with no power to the board at all??? Do you have a pace maker? Or maybe a flux capacitor in your back pocket?
