Author Topic: Adding effects loop to pedal?  (Read 876 times)
adam193
  • Diode Destroyer
« on: February 05, 2017, 03:11:40 PM »
The JHS Alpine has an effects loop built into it, its pretty cool...
#Invalid YouTube Link#
How hard is it to build something like this into a DIY Reverb pedal?
HamSandwich
  • Solder Ninja
Re: Adding effects loop to pedal?
« Reply #1 on: February 05, 2017, 09:16:46 PM »
Not really too hard, especially with a belton brick Reverb. Do you have a schematic?
sonnyboy27
  • Solder Ninja
  • Stephen
    • Prentiss Effects DIY Blog
« Reply #2 on: February 06, 2017, 08:52:16 AM »
I'm curious about this too. Particularly in regards to the BTDR-3. I imagine you would just be throwing something like a switching jack into one of the feedback/decay loops. But that seems too simple somehow. How would you do it in a Rub-a-dub deluxe?
http://1776effects.com/wp-content/uploads/2015/03/Rub-a-Dub-Deluxe-BOM.pdf
HamSandwich
  • Solder Ninja
« Reply #3 on: February 07, 2017, 08:23:13 PM »
That's exactly what I'd do. Put the switching jacks between lug 3 of mix and lug 1 of tone.
dbp512
  • Stompbox Star
  • Dave
« Reply #4 on: February 07, 2017, 09:59:29 PM »
Would you want it before or after the junction where that path splits off to R9? I thought you'd want the return loop to come back before it gets fed back into the brick, or is that situational dependent? I ask because I want to try and make my own shimmer, and for that effect at least, the octave up needs to be before the feedback loop (I think).
"you truly are a transistor tickler, what with the application of germanium ointment to sensitive fuzzy areas. :)" - playpunk
HamSandwich
  • Solder Ninja
« Reply #5 on: February 08, 2017, 08:36:19 PM »
Good question! I don't know the exact answer. If you wanted the effect to only be on the wet signal, than putting it where I said would work. If you wanted it to be within the feedback loop of the brick, I would think you're right, it would need to be elsewhere. I don't know what happens inside the brick - I don't know if the decay act as feedback. You'd have to play around or perhaps search the forums to find it.
If you really wanted that, you could make one of the reverb projects with pt2399's and have a much easier time finding the feedback loop (merlin's comes to mind). Unless there's a schematic for the brick, it will be hard to say for sure.
