Author Topic: What does a P6KE120 diode do?  (Read 847 times)
Tuxedo3
  • Stompbox Star
    • View Profile
« on: February 28, 2017, 01:33:04 PM »
Title mostly says it, I just don't know what it does. Is there a good replacement for it?
  • Electron Doctor
  • Jon P
    • View Profile
    • Midway Fair
Re: What does a P6KE120 diode do?
« Reply #1 on: February 28, 2017, 01:41:57 PM »
It does whatever is shown in the schematic that you didn't link us to!
Jebus
  • Solder Ninja
  • Kalle
    • View Profile
« Reply #2 on: March 01, 2017, 03:51:06 PM »
If you are looking to find out what it does in general a datasheet is good place to start: http://www.mouser.com/ds/2/240/Littelfuse_TVS-Diode_P6KE-48586.pdf
  • skilled electronics ninja master
  • Electron Doctor
  • Cody - Fresno CA USA
    • View Profile
    • My Blog
« Reply #3 on: March 01, 2017, 05:36:06 PM »
I bet someone is trying to build a BluesBreaker/Morning Glory work-a-like.
Tuxedo3
  • Stompbox Star
    • View Profile
« Reply #4 on: March 01, 2017, 08:05:32 PM »
You pretty much guessed it. Haberdasher has a Morning Glory schematic up on his "Morning Wood" project. I've built it and a few of my own bluesbreaker style drives i've just never known what that diode does.
Tuxedo3
  • Stompbox Star
    • View Profile
« Reply #5 on: March 01, 2017, 08:06:53 PM »
My fault, here it is.
galaxiex
  • Solder Ninja
  • Edmonton, Alberta Canada
    • View Profile
« Reply #6 on: March 01, 2017, 08:17:00 PM »
It's like a condom.... for your morning wood.... ;)
It's there for protection of the circuit in the event of reversed power supply polarity.
« Last Edit: March 01, 2017, 08:52:18 PM by galaxiex »
  • Electron Doctor
  • Jon P
    • View Profile
    • Midway Fair
« Reply #7 on: March 01, 2017, 08:53:56 PM »
It's nothing like a condom. Under proper use, a condom will prevent the things it's supposed to without breaking. That diode will break the second you ask it to perform it's function.
Just leave it out.
galaxiex
  • Solder Ninja
    • View Profile
« Reply #8 on: March 01, 2017, 10:35:43 PM »
Just leave it out.
With all due respect did you look at the data sheet for that device?
With it's rating I sincerely doubt it will break in the first second of reverse voltage from a measly 9 volts.
Vbr min/max 114/126 @ 1 amp.
  • Electron Doctor
  • Jon P
    • View Profile
    • Midway Fair
« Reply #9 on: March 02, 2017, 08:57:08 AM »
Just leave it out.
I'll play. With all due respect, would you take a moment to explain to me why the reverse breakdown voltage of a non-zener diode is relevant to its longevity when forward conducting 9V from a power supply delivering typically couple hundred to 2000 mA?
I will grant you it's probably better than a 1N4001, but if the diode doesn't die, the power supply still will.
EDIT: Also, I thought we were cracking jokes, not having a serious discussion about electronics. My bad.
« Last Edit: March 02, 2017, 08:58:42 AM by midwayfair »
AntKnee
  • Electron Doctor
  • Anthony
    • View Profile
« Reply #10 on: March 02, 2017, 03:03:59 PM »
Such respect!
