Aquaboy with dual MN3005 and modulation
Started by Boba7, March 16, 2017, 02:55:32 PM
Boba7
So here's another Aquaboy!
It was quite a lot of work I must admit, but what a BEAUTIFUL delay!
It runs at 15v from a Road rage board, except for the modulation board and the bypass board that run at 9v. The depth pot is 500kb (I used a tayda LDR and red led) with R8 being 1M and R5 2k I believe (faster speed). The modulation is footswitchable. The on/off led also indicates the modulation rate.
On the delay board, C10 is 220nf (standard), R13 and 14 are 56k (giving 7.5v on pin7 of the SA571n), and I've replaced R30 with a 100k trimpot.
I started with just one MN3005 chip, biased it and then decided to add another one with a daughterboard. It was fairly easy to bias, although it took quite some time. The headroom is great I think.
And the sound is just so beautiful, loads of mids (compared to a dark voiced PT2399 delay), a little grainy, a great character. I will oscillate but not until the feedback pot is around 3 (depending also on the time pot of course). The modulation is beautiful too, and much necessary in my opinion to give more space and magic to the repeats.
It was a long build, but not too difficult, and I must say again I'm very impressed with the boards. What a great job, THANKS!!
Decided to go for a reverse enclosure, not entirely sure I should have, it looked better in my mind, but oh well, it just sounds so great. Stazon ink and stamps, a few layers of coat, that's it. Oh yeah and of course, top jacks! :)
dan.schumaker
Looks great!  Looks like you are the first one to add a dual MN3005 board to your build.  There is a lot of awesome delay going on in a small box  :)
bsoncini
Nice. I'm gonna need to try this with mine.
cajone5
CurlyMo
That. Is. Awesome.
Sent from my XT1585 using Tapatalk
Philthy
Jmilla
That is awesome, I'm too chicken to try one of these.
JC103
What does the extra MN3005 do for the sound? Longer max delay time or more headroom?
AntKnee
I like how you used the bottom of the enclosure as the top. Interesting idea.
Boba7
Thanks guys!
Forgot to say the bypass board is from TH Custom and was used in 2 different builds some time ago, hence the slightly burnt pads...
Quote from: JC103 on March 17, 2017, 12:52:06 AM
With only one chip the maximum "clean" delay time was something like 270ms, now it's around 550ms without too much aliasing noise. I could definitely see the charm of having only 300ms or so but decided that I wanted more... :)
bluescage
Dminner
What size enclosure is that?  I have never seen a smaller one with 6 screws.
Cortexturizer
