Author Topic: Pork Barrel, no effect  (Read 571 times)
vinylkey
  • Diode Destroyer
« on: March 18, 2017, 01:48:30 PM »
I've gone through and checked all my resistor values and component orientation, still getting no effect, and some wonky voltage readings.  I haven't wired up R9 yet (planning on putting in a vibe switch) but if I place the resistor in the holes, I still get dry signal with the effect engaged. The rate LED lights up and changes with the Rate knob.
Here are my IC voltage readings:
IC1IC2IC3IC4
2.1708.64oscillates
2.184.184.164.5
2.171.570oscillates
08.084.180
2.178.64275mv, osciilates4.58
2.184.168.34.62
2.184.592.75, oscillatesoscillates
8.854.68.088.68
Transistor voltages:
Q1Q2Q3Q4Q5
C8.818.818.818.62   7.4
B1.922.091.98oscillates   350 mv
E1.421.541.46oscillates   0
V+ measured at the board is 9.08 (coming from a wall wart)
Any help would be greatly appreciated!
« Last Edit: March 18, 2017, 01:55:51 PM by vinylkey »
bsoncini
  • Solder Ninja
Re: Pork Barrel, no effect
« Reply #1 on: March 18, 2017, 03:05:29 PM »
You might need to redo some of your solder joints. Notably the transistor and diode in the top right in the first photo. And some of the resistor a below the v3207.
A good solder joint should look like this
http://diy.koenigs.dk/wp-content/uploads//2014/02/f07cf7b0d360dfc9184fac3b5c59254a92f8f56b.png
Might wanna socket your transistors in the future. It's possible to get a bad one or fake. Or that you fry it while soldering.
And build yourself an audio probe.
« Last Edit: March 18, 2017, 03:08:23 PM by bsoncini »
« Reply #2 on: March 18, 2017, 11:13:15 PM »
Its fairly unlikely with the coolaudio chips, but are you 100% sure your BBD is legitimate? I've gotten burned by ebay 3007's in the past. (Even if they were real chips they shipped them on styrofoam, poor things were toast)
hoodoo
  • Matt
« Reply #3 on: March 18, 2017, 11:15:30 PM »
Hey mate, check the build doc. There is a resistor linking pins on an IC, that you might need.
vinylkey
  • Diode Destroyer
« Reply #4 on: March 19, 2017, 02:01:35 PM »
R9? I don't have that in yet because I'm planning on doing the Vibe switch mod.
I'm pretty sure I got them from Smallbear, but I don't know how likely a dead or counterfeit chip is from them. Unfortunately, I didn't order any spares, so I can't check with another one yet.
Thanks for the tips! I'll redo some of the poor solder joints and see what happens. I can make an audio probe and see where the effect signal starts to die.
« Reply #5 on: March 19, 2017, 04:43:06 PM »
If its from Smallbear its a legit chip. There is a small chance it may have been damaged on installation, but that is a bottom of the list sort of error in figuring out the problem. Definitely recheck all the solder joints, and look carefully to make sure there aren't any hair-fine bridges anywhere.
Also, is smallbear where you got the diffuse blue LED? I've wanted a few of those in the past but my usual suppliers don't carry them (that I know of, anyway)
vinylkey
  • Diode Destroyer
« Reply #6 on: March 20, 2017, 11:07:46 PM »
I think I got the diffuse LEDs from Mouser.
I reflowed a handful of the solder joints on the board, and got wet signal to come through! At first I was worried, because the wet signal still didn't have any effect. So fun fact: you don't get any effect when a trim pot that controls the effect level is turned down all the way  ::)
Thanks for all the help, I'm glad to finally have this thing working!
« Last Edit: March 21, 2017, 12:05:06 AM by vinylkey »
mrclean77
  • Solder Ninja
« Reply #7 on: May 02, 2017, 04:13:01 PM »
So, with the rev.1 boards - the R29 jumper; 10k across IC4 pin 4-5 fix is still required???
TIA everyone
mrclean77
  • Solder Ninja
« Reply #8 on: May 08, 2017, 04:54:34 PM »
Bumping again instead of making a new thread.
-Rate led stays lit, not changing w rate control
-no effect unless I strum then manually rotate depth control back n forth
-audio probe didn't reveal anything
-could not see any solder bridges
-jumper and 10k across pins 4-5 as per instructions
I'm betting a piece of unchewed bubble gum this is a simple fix, but it's whooping me so far. TIA
mrclean77
  • Solder Ninja
« Reply #9 on: May 15, 2017, 08:23:36 PM »
Ok, so if you have the "rev.1" board - DON'T do the fix on page 10.
I thought I had saved the most updated pdf guide...nope.
Ugh.
