I've had a bit of back and forth discussion with Peter in the last couple of weeks about the dual switching mode in these projects. The way it is supposed to work is as described in the build doc - to switch to momentary mode you wait 5 sec, tap the switch twice and hold, then wait for the LED to blink to confirm momentary mode. This works perfectly. It's going back to latching mode where the problem arises. To switch back, the process should be the same. Unfortunately, this doesn't seem to be the case.
At first I thought I was just doing it wrong, but after making a video of it and sending it to Peter he confirmed this is an issue with the programming of the chips. So, for now to undo the momentary mode and go back to latching the power must be unplugged to reset the switching. I realize this is not terribly convenient and I am sorry that it is not working as it should be. Unfortunately, since I do not have access to the switching code it isn't a matter of me trying to re-program the micro-controllers to make them work correctly. These are programmed by a third party, and I purchase them directly from Peter as part of our agreement. So, we are stuck with this for the foreseeable future. It may be fixed in future batches but I have a substantial number of the micro-controllers on-hand so it is not likely to change in the next few months.
Again, I apologize for this glitch and I hope it doesn't cause too much disappointment for those of you who are building these projects.
