WEENER WAH (1st version): Use the output buffer as buffered bypass
Started by Billy_Vegas, June 11, 2017, 09:46:55 PM
Billy_Vegas
Hi guys, hi Brian. Is it possible to use the output buffer of the older version of the Weener as a bypass buffer? Here's the building doc:
http://www.madbeanpedals.com/projects/WeenerWah/WeenerWah.pdf
Thanks!
drolo
certainly possible, you would need to cut the trace between the output of the wah and the input of the buffer (between C3 and C7) and insert your bypass switch there
