September Happenings
Started by madbean, August 29, 2011, 08:03:29 AM
Anything that has board mounted pots will include a precise drilling file in the project documentation.
jimmybjj
sweet that is what i was hoping for .
Pcbs no longer available
I go at it a bit differently.
Usually you can find out how far apart the centre lugs are from each other. Say for example that two pots side by side are 0.8" apart (like in a lot of my layouts). The holes for the pots willbe drilled 0.8" side by side. I use a vector graphics program to create my graphic layouts, and I prin out a version that includes markings for using a centre punch to mark out my pots, switch and led.
dwstanford
Quote from: madbean on September 03, 2011, 05:20:28 AM
Thats good.  I've never used any of the drilling templates, but i'll probably have to with the board mounted stuff.  When i did the fuzz factory with 9mm pots, i just kinda eyeballed everything and it was a pain.  i kept having to bore out holes to make everything fit.
aflynt
Quote from: jkokura on September 03, 2011, 10:33:57 AM
That's exactly what I do.
-Aaron
In the case of the Fuzz Factory, another thing you can do is take the actual board, lay it out on top of the enclosure, then use a pencil and colour in the middle hole for each pot (lug 2). If you are careful, use some painters tape and also mark a line on it before hand for both the centre of the enclosure, and the line you want the pots to line up on a perpendicular to the centre of the enclosure. Line up the middle lug'sd middle hole and BAM. You've got yourself a smoothly awesome very easy to drill set of holes.
Quote from: jkokura on September 03, 2011, 10:04:39 PM
Thats a good tip there.
Drilling enclosures is my least favourite part of building pedals.
I even bought a drill press (£50 !!!) and still find it a bind.
DuctTapeRiot
Any update on when the new Pork Barrel boards will be up for sale??  My Small Bear order is on the way and I am jonsin!!  ;D
The order has been placed and it will be here in less than two weeks, I think.
insomniac2295
EgoDriver, Pork Barrel, Low Rider, Green Bean, Pepper Spray, Mudbunny and the Slow Loris will all drop on the same day.
groovybenny
#71
How long until the dirtbag delay is ready?
Cheers
Edit: Found some info- October =)
Mike @ Rawkworks
Should I run into a wall at full sprint or down a couple cases of beer to make the next 3 days go by faster?
Mike
mike@rawkworks.com
rullywowr
Quote from: tyronethebig on September 22, 2011, 06:01:51 PM
No on the wall, but yes to the BEER! ;D
insomniac2295
