Choral Reef
Started by madbean, July 17, 2017, 03:13:29 PM
Plus I figure I'm paying Steve back for sticking his neck out to stock these.
lego4040
I wouldn't buy outside of SmallBear unless it came from a reputable source, ebay🤣 Since my vacation screwup I'm strapped for cash. I should have most parts in the bin though
Quote from: Droogie on August 07, 2017, 02:46:16 PM
How important is the 14k3 resistor values to be exact? If I don't have to order such an odd value it would be really swell. Would 15k work?
If we use the old EHX wisdom, super precise resistor values on schematics usually meant "these guys are important, check their value to make sure they're in spec", rather than needing that specific exact value.
In this case, looking at the schematic, I would say just buy 20~ 5% tolerance 15k resistors and meter them to find 4 that are all fairly close to one another on the small side of the range. They wouldnt need to be 14.3k exactly (since they're all in line with the pot after all), but they should all be about the same value.
(And yes I'm mostly writing this to talk myself out of buying 200 14.3k resistors from Mouser since that is their minimum order...)
lego4040
I'm putting my orders in for the various parts this gem will need but Is there a alternative to the TLE2074? While searching this, I found a similar question on this here on this forum. Some one was looking for a alternate to the LF347, both quad op amps and the TLE2074 was suggested. LF347=75cents &TLE2074=6bucks
Quote from: lego4040 on August 14, 2017, 12:13:47 AM
The tle2074 is basically a super high end tl074. Triple the slew rate, twice the bandwidth,  all the bells and whistles.  In theory the 074 should drop in. Try it, if unhappy you can then get the tle2074 from arrow with free shipping later.
lego4040
I figured the reasoning was the all around quality, VFE's arent throwing in crappy noisey parts. Thanks
Yeah, I don't see any reason for a TL074 not to work. I'm sure the TLE2074 was chosen in keeping with the idea of highest headroom / fidelity as possible. An alternative would be a different rail to rail like the TLC2264 which should be about half the price.
lego4040
I started ordering parts, some from SmallBear/Tayda and tonight is Mouser. I don't understand the rail to rail lingo but I do see the pin out is the same. Maybe I'll get a TL074/TLE2074 and the TLC2264 to compare. I watched the video from switching board link. These vfe's are some serious thought out effects. I'm still sorting out quirks on my Tourbillon and thinking I'm screwed if I have to trouble shoot this
Many op-amps are designed for bi-polar supply (+/- DC) but are limited in how much a voltage output can "swing to the rails" during operation. A rail to rail op-amp is designed to run off a single supply (here 9v) and the output can get very close to the positive rail while maintaining a high dynamic range.
lego4040
Thanks for the explanation, so if you needed more voltage for bigger headroom your not getting it from this rail to rail chip. I like headroom,  TLE2074 it will be
BrianS
Quote from: lego4040 on August 14, 2017, 03:08:43 PM
The VFE projects are the easiest pedals I've built.  One thing I've noticed is there's not many, "I'm having a problem," posts and the ones (mine and one other) were self induced mistakes.  I finished my Choral Reef yesterday and after fixing the power wires which were switched wrong the pedal fired right up.  So that's 3 for 3 on these knock on wood.
is everyone building this with those small pots or are some of you doing offboard wiring to regular size pots?
Quote from: peAk on August 15, 2017, 12:01:48 PM
I'm building to spec: 2x 9mm pots, 3x 16mm pots, 1 switch. The 9mm's are the plastic shafted variety used in the production model.
Not a lot of room in the 1590B to move things around I'd wager. The layout is about as size efficient as it can be.
lego4040
I bought everything as per spec except enclosure so far. Measure 10xs then drill once🙄
Quote from: somnif on August 15, 2017, 12:32:51 PM
oh yeah, I was just thinking about going a little larger on the enclosure.
