Up Down Daddy and other fun
Started by jimilee, July 24, 2017, 06:12:41 PM
Is there a demo of that octaves around?
Jimi these look fantastic. The artwork on both are great.
Quote from: Matmosphere on July 25, 2017, 04:25:43 PM
Not yet, but I can I.
Jaga
Hello everyone!
I'm building this PCB and it is not working. I've measured some voltages, but not sure how to debug further. Probably someone could give some advice based on the measurements.
In the output of the effect I could hardly hear dry signal. Normal and upper octave pots are working: if they are all the way down to 0, there are no output at all, but if I turn them all the way up, very quiet signal appears. The other 2 pots are not affecting the sound.
Inside the scrollable block is what I have:
CD4013 near C1 ceramic cap
1   0
2   8.9
3   0
4   7.63
5   0
6   0
7   0
8   0
9   8.9
10  0
11  8.9
12  8.9
13  0
14  8.9
Another CD4013
1   0
2   8.9
3   8.9
4   0
5   8.9
6   0
7   0
8   0
9   0
10  0
11  0
12  0
13  8.9
14  8.9
TL074 near the trimmer
1   4.88
2   4.87
3   4.87
4   8.9
5   4.87
6   4.87
7   4.84
8   4.9
9   4.88 (for some reason I heard buzz while measuring voltage here)
10  4.87
11  0
12  4.87
13  4.87
14  4.65
Another TL074
1   4.87
2   4.87
3   4.85
4   8.9
5   4.56 (for some reason I heard buzz while measuring voltage here)
6   4.87
7   4.87
8   4.87
9   4.87
10  4.86
11  0
12  4.58 (for some reason I heard buzz while measuring voltage here)
13  4.87
14  4.87
LM324
1   4.87
2   4.88
3   4.85
4   8.9
5   4.85
6   4.88
7   4.83
8   0
9   4.88
10  4.87
11  0
12  4.87
13  4.87
14  7.65
TL072
1   4.86
2   4.88
3   4.45
4   0
5   4.59 (for some reason I heard buzz while measuring voltage here)
6   4.88
7   4.88
8   8.9
J201
D   8.9
S   8.2
G   8.9
2N5457 (near the PCB's corner)
D   4.85
S   4.87
G   0
2N5457 (in the center of PCB)
D   4.86
S   4.87
G   4.27
I made some tests using audioprobe, but I'm not sure how to follow the signal. I can hear dry signal in the beginning of the circuit, but then it is hard to follow it. There are some interesting points on LM324 though:
1    Loud dry signal with some noise
2–6  Very quiet dry signal
7    Loud dry signal with some noise
8    Some quiet hiss
9    No sound
10   Something very quiet but lower than dry signal (not sure if it octave lower or two)
11   No sound
12   No sound
13   Something very quiet but lower than dry signal (not sure if it octave lower or two)
14   Very quiet dry signal
Would be grateful for any help if something can be done with the PCB apart from trying one more time from scratch.
Thank you.
