Author Topic: Tractor Beam update  (Read 2212 times)
  • Administrator
  • Brian
Tractor Beam update
« on: August 12, 2017, 06:15:01 PM »
Progress has been made on the Tractor Beam (phaser) and is on schedule for release probably in 7-10 days. I got the audio board populated after waiting on a couple parts from Mouser. The Tractor Beam was originally called the Enterprise and is built on the same board. There are a few value tweaks from the Enterprise so the pot values here are not all accurate.
This will be a difficult build, but if you have done one of the VFE already it shouldn't be too bad. There is on electro that has to be soldered in parallel with a Zener (top right). There are three resistor networks (two 10k and one 22k). It also requires four matched 2n5952 FETs. I actually had a set I previously matched for a different project and was no longer using. The doc will have instructions on how to match FETs (I think I may have already covered this in the Phase 90 doc). The "B10k" is actually 1k now, and only having 2k on-hand I soldered in another 2k resistor in parallel with it.
Also, I have a FET matching board I may just put up on OSH Park. It was supposed to be part of a small batch of utility boards I was going to offer for sale but I never got around to it.
Anyway, to do: build the switching board and test it out. My prototypes for the re-designs of the VFE switching board will be here in a few days so I think I will wait and test one of those out with this build.
Zigcat
  • Stompbox Star
  • Andrew S.
Re: Tractor Beam update
« Reply #1 on: August 12, 2017, 06:45:19 PM »
Decent!
BrianS
« Reply #2 on: August 13, 2017, 03:33:46 PM »
Brian,
Anyway you might beable to post the board page with all the parts like you did with the Choral Reef? If you can't it's no big deal. Thanks.
lego4040
  • Stompbox Star
« Reply #3 on: August 13, 2017, 06:04:12 PM »
awesome, will keep watch
Ralfg
  • Solder Ninja
  • Ralf
« Reply #4 on: August 13, 2017, 07:49:28 PM »
What Function F(x) board is that in the background?
  • Felix - Graz, Austria
    • My blog - in german
« Reply #5 on: August 14, 2017, 01:53:57 AM »
should be the clusterfuzz.
that phaser layout is really closely packed...
My etching tutorial
dan.schumaker
  • Solder Ninja
  • Schu-Tone
« Reply #6 on: August 14, 2017, 06:50:02 AM »
That looks really cool.  Never used resistor array's before.  Looks like a really smart way to save a lot of space on a really packed board.
  • Administrator
  • Brian
« Reply #7 on: September 12, 2017, 08:50:01 AM »
Here is the draft of the Tractor Beam BOM/Shopping list. I have a bit of debugging to do on my build but I believe this list is accurate.
dan.schumaker
  • Solder Ninja
  • Schu-Tone
« Reply #8 on: September 12, 2017, 08:52:34 AM »
As always, thanks Brian!
Hirti
  • Diode Destroyer
« Reply #9 on: September 12, 2017, 09:17:55 AM »
Thank you!
hasanova
  • Diode Destroyer
« Reply #10 on: September 13, 2017, 06:17:58 PM »
Cheers!
tcpoint
  • Solder Ninja
« Reply #11 on: September 14, 2017, 04:44:43 PM »
The 1.43K resistor that you link to mouser is way too big.  It's a Vishay Dale that's the same size as a 1/2 watt Xicon.   I did a quick search but couldn't find anything suitable.  I'll probably get some smd resistors of that value and make them work.  After all, it's diy.
« Last Edit: September 14, 2017, 05:01:43 PM by tcpoint »
  • Administrator
  • Brian
« Reply #12 on: September 14, 2017, 05:46:39 PM »
Huh - 8mm. That is a bit long (though they could be made standing). Here are two 6mm ones (still a bit long):
http://www.mouser.com/ProductDetail/Vishay-Dale/RN55D1431FRE6/?qs=sGAEpiMZZMu61qfTUdNhGzQiLrTi4xBWc4N7jZ0yHC0%3d
http://www.mouser.com/ProductDetail/Vishay-Dale/RN55D1431FB14/?qs=sGAEpiMZZMu61qfTUdNhG3gu04FpCMicro03p17NpK8%3d
Thanks for posting that. I forget which one I used...I'll have to look.
Jules
  • Solder Ninja
« Reply #13 on: October 07, 2017, 03:47:55 AM »
Have you made any progress with the debugging of your build Brian?
Just in case you read this, thanks.
I have been really enjoying these VFE builds.
  • Administrator
  • Brian
« Reply #14 on: October 10, 2017, 06:33:43 PM »
Yeah, it's pretty much done. Should be releasing later this week. Turns out it was user error. I'm the user.
