Author Topic: Grind Customs LFO Board  (Read 432 times)
BrianS
« on: August 26, 2017, 08:56:22 AM »
I got this board in trade to put in a Sagan delay and its the old version, i.e., LFO not PLFO.  So the 3 pads (Sqr, blank, Sin) are missing on the board and I already drilled the hole to use a switch to control this function.  First, does anyone have a build doc for the LFO version?  Second I am thinking I can jump wires connecting the points to make this work as follows:
SQR -  R3 leg to IC pin 3 and to switch.
Blank pad -  IC pin 5 to switch
SIN -  R5 to R4 to switch
Does this look right or is it a complete no go and of course this is assuming that the old board is traced like the new one?  I really need some more experienced eyes than mine to tell me if this is going to work.
Soup39
  • Stompbox Star
Re: Grind Customs LFO Board
« Reply #1 on: August 27, 2017, 05:53:48 AM »
Aren't the pads between the rate & depth pots for the switch?  They are labeled sqr/blank/sin.
Philthy
  • Stompbox Star
  • Oz
« Reply #2 on: August 27, 2017, 05:34:34 PM »
see here - should answer your questions: http://www.madbeanpedals.com/forum/index.php?topic=25400.0
BrianS
« Reply #3 on: August 27, 2017, 09:46:41 PM »
Yes they are but I don't have that board.
Thanks for the try but it's the build doc for the PLFO.
chordball
  • Solder Ninja
« Reply #4 on: August 28, 2017, 08:17:58 AM »
If the old board doesn't have pads for the switch, then you will need to make some trace cuts and find a way to tap those places you've identified. Can you post a picture of your LFO board?
    • Project Website
« Reply #5 on: August 28, 2017, 11:13:12 AM »
Geez Brian, didn't realize there was more than one version.  Sorry about that.
  • Cody - Fresno CA USA
    • My Blog
« Reply #6 on: August 28, 2017, 07:19:35 PM »
Take a picture of the actual PCB you have. It will help.
BrianS
« Reply #7 on: August 28, 2017, 07:37:35 PM »
It's ok Grody.  I think I have it figured out.
JuanSolo sent me the schematic this morning and Mike Flanagan gave me the info to cut and wire it to work like the PLFO.  Just hope it's works.  Wish Rej would open back up.  Thanks for helping.
BrianS
« Reply #8 on: August 28, 2017, 07:44:57 PM »
Sorry I wasn't ignoring your post LOL.  Thanks for the suggestion.
    • My Blog
« Reply #9 on: August 28, 2017, 07:49:56 PM »
Glad you got it sorted.
The LFO board was an old one no longer sold by GCFX and was replaced with the PLFO PCB. I'm glad that JuanSolo had the schematic since I was having no luck locating it. The shop currently has plenty of the PLFO boards in stock and orders are being fulfilled from the GCFX shop currently.
BrianS
« Reply #10 on: August 28, 2017, 08:35:22 PM »
Wow that's great.  I was unaware that orders were being processed again.  I still thought things were sort of shutoff for the time being.  Buying one would have saved me a lot of frustration lol.  If this one doesn't work I will order one.  Thanks For the info Cody.
chordball
  • Solder Ninja
« Reply #11 on: August 28, 2017, 09:09:18 PM »
No worries man. I figured someone out there had the doc for it. Glad it's sorted.
