Author Topic: LaserWolf Order Switch Pad Jumpers  (Read 190 times)
Cybercow
  • Diode Destroyer
  • Moo
« on: August 30, 2017, 02:49:58 PM »
If I've done my homework right, I should be able to configure the order switch-pads on the LaserWolf to get an OverDrive - Phaser - Delay circuit order using the connections indicated in the attached image. I' just looking for another set of LaserWolf-aware eyes to verify. tia
Cybercow - aka: Mark Davis
 "Don't let your talent take you where your character can't keep you."
Cybercow
  • Diode Destroyer
  • Moo
Re: LaserWolf Order Switch Pad Jumpers
« Reply #1 on: September 07, 2017, 08:41:21 AM »
It appears I did my homework right and the order change worked as hoped in the original post. My LaserWolf is now ordered as OverDrive - Phaser - Delay. (using the jumpers noted in the original post)
