August build - Liquid Mercury Phaser
Started by cresconio, September 03, 2017, 12:07:06 PM
cresconio
Presenting the August build: Liquid Mercury by David Rolo
A great sounding tap tempo phaser based on the TAPLFO chip by Electric Druid. It uses a subset of 4 different LFO's instead of all 8. I really like the random LFO. Unfortunately I didn't make a demo of that, but it really gives some nice effects.
This is by far the most difficult build I've done. I spent most of the time getting the jacks to fit.I had to mangle the external jack for the tap tempo, allowing me to synchronize multiple pedals using the TAPLFO chip, so it could fit. I didn't have much room because of the 2 pcb's stacked on top of each other
As usual, I put a video online to demonstrate this awesome sounding pedal:
Martan
Looks Great! Its a great sounding pedal. You are right about the tight fit. How does your external tap jack work? Is it from the momentary switch or from the TAPLFO output?
Marty
BrianS
Real nice. Love David's boards.  Sounds really good.
cresconio
I connected it to the momentary switch, from there it is connected to the TAPLFO chip
Quote from: Martan on September 03, 2017, 12:22:10 PM
Marty
drolo
nice demo, really like the moon cycle dials :-)
rockola
cresconio
Thanks!
The riff is from Bridge of sighs by Robin Trower
Quote from: rockola on September 27, 2017, 02:42:08 PM
Nice work! What's the riff @ 3:19?
cresconio
Fun pedal to play with, thanks for your work! Only need to tweak the output volume a bit as it's a bit below unity for me at the moment.
Also, you might've noticed the bipolar bear right next to it ;). They work great together but you probably already knew that.
Quote from: drolo on September 27, 2017, 09:22:40 AM
drolo
