Author Topic: Another ROG: the Tri-Vibe from TH Custom  (Read 437 times)
Max
  • Transistor Tickler
« on: September 09, 2017, 03:33:01 PM »
Hi guys, I finally managed to put together this nice little circuit. I had some issues with the decal and the colour printer at work and it took me way too much time to finish the enclosure. Not to mentioned that when I got the decal printed to perfection the first time, I didn't spray enough coating on it and the ink started to smudge during the application :'( :'(
I borrowed the image for the graphic from some website, I'm not that creative  ;D ;D
About the circuit: the central position of the switch (Vibe) is so subtle that at first I thought it was not working at all. Is it how it should be?
I find the other positions just great.
Enjoy:
https://drive.google.com/open?id=0B5Uj9BTxpfvLbXdUTUNSYWRqams
https://drive.google.com/open?id=0B5Uj9BTxpfvLeVMxS0NPZVF3Rlk
« Last Edit: September 09, 2017, 03:34:48 PM by Max »
Matmosphere
  • Matthew
Re: Another ROG: the Tri-Vibe from TH Custom
« Reply #1 on: September 09, 2017, 03:54:20 PM »
Whoa, that's a nice build. The artwork is very cool. Did you draw it?
Max
« Reply #2 on: September 09, 2017, 04:05:13 PM »
Thanks  :D
I found the picture on some site, adapted it to the size of the enclosure adding some colour fade at the bottom, and added the text. I thought it would fit with some purple around, and I'm quite happy with the result.
bsoncini
  • Solder Ninja
« Reply #3 on: September 09, 2017, 04:30:40 PM »
Nice build.
In mine the vibe (middle position) is much more subtle than the two others.  Need to turn the rate up pretty fast to notice.
Max
« Reply #4 on: September 10, 2017, 04:19:24 AM »
Yep, it's what happens with mine. Good.
