Dimension-C in a 1590B
Started by EBK, September 11, 2017, 08:22:13 PM
if you feel the chorus is too loud, replace R9 with a 100k trimmer and dial it down
but of course you would have to take it apart a bit to do that  ;D ;D ;D ;D
Quote from: LaceSensor on October 03, 2017, 04:06:08 PM
Mine seemed ok to me (stock bypass).  Just ever-so-slightly louder (not even something I'd call louder, per se), realistically like a second guitar just joined in.
Wow, I really suck at finishing things!
Was originally going to laser etch this, but decided to try a decal instead.  Some roughness on the edges, but not too bad.
Left some water on it in my hurry to take a picture.   ::)
I still have a chance to mess this up.
Edit:  A dry pic:
Adam_DIY
Quote from: Adam_MD on June 27, 2019, 12:28:28 PM
Love this thread
Glad you like it.   :)
Update: So I cut the holes, and it did not go perfectly, but I have a nice solution.  The LED hole got crappy white edges like the stomp switch in this pic, but I have some modular furniture shelf pin sleeve grommets (basically eyelets) left over from my Theremin Fuzz build.
Aentons
Very cool. How you get the white letters? What kind of decal is that?
Quote from: Aentons on June 28, 2019, 06:14:48 PM
It's a white decal, inverse printed, i.e., I matched the cobalt blue through trial and error.  Color laser printer.
This is the specific product:
https://www.amazon.com/dp/B078WTL24B/ref=cm_sw_r_cp_awdb_t1_Y0RfDbZCX01Q3
I like the detailing with the output jacks' writing slowly dividing
Quote from: alanp on June 28, 2019, 10:36:57 PM
I had to label which jack was stereo somehow.   ;)
Glad you like it.
MAJOR setback with this project:
No idea how this happened.  The finish seemed so stable for so many weeks up until now.  :'(
That looks like ice crystals, so cool :)
Aentons
It does look pretty cool like that... Is that in the clear coat, or did it fall into your vat of meth? :)
That's very strange.  I've had that happen but not weeks down the road.
Quote from: alanp on August 19, 2019, 06:01:16 AM
I wonder if I can remove this with an ice scraper.  (I might actually try something like that to salvage this.)
Quote from: EBK on August 19, 2019, 05:45:07 AM
Is that a painted enclosure or is it powder coated?
If it is painted, did you use an enamel based paint and then try to clear it with lacquer? That would explain those results.
