The Hype
Started by juansolo, September 13, 2017, 12:52:56 PM
A clone of a Devi Hyperion for a fella who bought a BeeBaa clone from us in a purge. He wanted this to match aesthetically. I like to think it's a little tidier than a real one...
Luke51411
That's badass! I love how empty the box looks.
chordball
Awesome
BrianS
That graphic is really neat.  Inside is as you say tidy. Under statement.
well, as clean as it gets.
so, in all honesty: how many times did you have to use a new piece of ribbon wire before all wires had the perfect length?
Quote from: m-Kresol on September 13, 2017, 04:13:12 PM
I have a technique for doing that... That's the only one I used ;)
FWIW if I can I have a template that I try to make all our pedals to now. So I have an old back-plate that's pre-drilled with a few pedal layouts on it. I build the effect on there and attach the ribbon to it then too. The stomp end of the ribbon is left over-long for testing then is trimmed back when I fit it into the pedal. All much easier than doing it in the box.
Also FWIW, it's a Devi, at some settings it sounds broken, at others it doesn't sound bad. Not one I'd build for myself but it's a shitload better than a Sodameiser.
storyboardist
+1 to what everyone else already said! Unbelievably clean vero build.
Guy behind Effects Layouts
Where's the rest of the guts?
Quote from: alanp on September 14, 2017, 04:04:28 AM
Clearly they fell through the portal.
Top notch work as always Juan. far more polished than any "boutique " I can think of.
diablochris6
Clean, inside and out. I own an old Sodameiser, and the PCB is just dangling by all the off-board wiring and is wrapped in electrical tape.
mrclean77
Clean as always, love the artwork and +1 on clean vero build(s) - you make the seemingly impossible look like child's play
Quote from: juansolo on September 13, 2017, 08:08:43 PMSo I have an old back-plate that's pre-drilled with a few pedal layouts on it.
10000% stealing this idea  8)
