Reliable Source for LM308s?
Started by mremic01, October 19, 2017, 07:41:55 AM
chromesphere
Mainly ICs and Transistors.  Things that have a bit of worth. J201's, BBDS, etc.  Germanium transistors are usually ok.
Philtre
Banzai in Germany sell LM308s. How would one know upfront if these are genuine?
http://www.banzaimusic.com/LM308N.html
Adam_DIY
Quote from: Philtre on June 13, 2018, 10:42:38 PM
They'll be real if they actually have them.  The problem with Banzai is they are either fantastic or fantastically useless.  Basically if you submit an order and they have everything you'll get it in about a week from Germany to the uk.  If, however, one of the items is actually out of stock (though was probably showing as in stock when you ordered) they'll hold the entire shipment and not contact you until you harass them by email 3 or 4 times then they'll ship the parts they do have and either offer a refund on the outstanding one or ask if you want to wait and ship it separately.
That's been my experience.
bsoncini
I have to go here often for work. I can pick you one up if u want. http://www.stquentin-radio.com/?page=info_produit&info=5052&color=3&id=0&act=0
It's pretty sure they are legit. I've bought a few from them. €4 plus maybe another €2 for shipping.
Philtre
Quote from: bsoncini on June 14, 2018, 09:26:47 AM
Many thanks for the offer. But I'm going to stick with OP07s. :-)
bsoncini
No problem. Let me know if you change your mind.
I've been playing in a group as a duo recently. Me on guitar and a drummer. I've been using this pedal a lot to have some more bass.
Philtre
I've been researching LM308 vs OP07.
The tech sheet for the OP07 has pins 1 & 8 as an offset nulling option where it seems a variable resistor can be connected. Yet, on various forums discussing the ins and outs of OP07 vs LM308 some people swear that adding a compensation cap on 1 & 8 on the OP07 makes a difference to the sound (example - https://www.thegearpage.net/board/index.php?threads/rat-op-amp-chips.1326447/)
What do the experts think?
reddesert
#52
I mistrust thegearpage as a source for technical information, generally (although I don't read it often and may be a grump).
The LM308 is a really old op-amp. Back then, fabrication techniques made it hard to put an internal capacitor on the chip. So op-amps like the LM308 relied on an external compensation capacitor. The point of this cap is to avoid oscillations at high frequencies (above the audio band) that would make the op-amp unstable. For complex reasons, the amplifier has a phase shift that changes with frequency, and at the frequency where it is 180 degrees out of phase, the negative feedback would change to positive and cause oscillation. The compensation cap rolls off this behavior.
Later op-amps like the 741 and OP07 were made with a small capacitor on the chip, so the external compensation is not necessary and the pins are used for offset nulling (which is AFAIK something to use for precision DC differential amplifiers and irrelevant for audio circuits). If you compare the schematics of the LM308 and OP07 in the gearpage thread, the OP07 has a small cap C1 from V+ to the collectors of Q9 and Q10, while the LM308 has no capacitor on-chip.
For more information about the history behind this, look at section 4 of the History of Op-Amps book chapter at http://www.analog.com/media/en/training-seminars/design-handbooks/Op-Amp-Applications/SectionH.pdf. By the way, Sections 1-3 will happily lead you down a rabbit-hole of reading about early vacuum-tube and discrete op-amps. Here's a screen-cap of a footnote about the internal compensation capacitor:
I don't think adding a cap between the offset null pins of an OP07 or similar is going to do anything to modify the high frequency behavior, nor is it necessary.
However, I've not been convinced that the LM308's low slew rate is what gives it the mojo sound. Its slew rate is still quite adequate for audio signals.
Philtre
Thanks for that info, redderset, very informative. :-)
For my own part I've tried an OP07 and an LM741 and, to me ears, there's very little in it. I might try a LM301 at some point but I'm fast coming to the conclusion that it's just not worth the bother fretting over this, and just bung in an OP07 without a compensation cap and be done with it. I believe that modern Rats use them.
Boba7
Very interesting thread. When I swapped an lm308 for an Op07 a few months ago I was surprised that I could barely hear a difference. And I'm pretty sure I took out the 30pf with the OP07 and it made no difference either.
stevie1556
I've often found that AliExpress is good for rare parts. Yes, I know they are fake, but if you order some and then test them you can generally find the good sellers pretty quickly. I get a lot of SMD parts from there, especially the transistors and diodes because either I can't source them elsewhere or the minimum quantanty is rediculous.
But like I say, I test the parts before using them to ensure that they are within spec of the original ones, and haven't had an issue so far.
Sent from my SM-G955F using Tapatalk
Philtre
I did an experiment. I built a RAT clone (http://tagboardeffects.blogspot.com/2012/01/proco-rat.html) and ordered some LM301s from Tayda and tried the following:
- OP07 (no compensation cap)
- LM301 with 100pf compensation cap
- LM301 with 33pf compensation cap
I know it's subjective but, for me, the last option won. Sounded a bit grittier.
(BTW - the Tayda LM301s are genuine as they squeal like a pig without the cap unlike the "LM308" I bought off eBay which was a repainted OP07)
Quote from: stevie1556 on June 20, 2018, 05:20:30 PM
Just be wary of the places that sell end of life parts with a listed production capacity of 10,000 pieces per day.  ;-)
reddesert
My 2 cents on "fake" parts (I know we've been around this before): It's common in the electronics industry to "second-source" parts. This means that there is some other manufacturer making, say, a dual op-amp that works like a JRC/NJM4558 and calling it a 4558.  This is not considered a fake (unless they counterfeit the manufacturer logo).
Then there's the parts that either grossly fail to meet spec or are just some other random IC with the name of a hard-to-find chip like a CA3080 printed on them. These are fakes (real fakes? fake fakes?) and will lead to frustration.
As a generalization, I would consider buying an easy to find item on ebay or wherever (of course, if it's easy to find, I can probably get it from a regular suppier), but if it's exotic and the price is too good to be true, it probably is.
Quote from: reddesert on June 30, 2018, 05:11:02 PM
In China, there are a lot of second tier electronics houses where you can buy parts.  I deal with folks in China on a regular basis and asked somebody to get some JFETs for me from one of the local houses that had stock (this was soon after they went EOL).  I ordered 2n5457 and J201.  Not only were they all out of spec, some were actually P-Channel.  They were marked with the right names, but the logos were off.  Oh well.
