Author Topic: Aquaboy Whine in bypass  (Read 1390 times)
Niketplos
  • Diode Destroyer
Re: Aquaboy Whine in bypass
« Reply #15 on: June 10, 2018, 06:45:52 AM »
So im having the same issue with the clock noise whine only when i run a longer wire to the switch its still there. Now my pots are not mounted to the board so there is a bit of wire connected the delay pot. Could that be the issue? i even took the output jack out of the case and took the ground for it off the board and grounded it separately but still there.
« Last Edit: June 10, 2018, 06:47:38 AM by Niketplos »
awaroa
  • Diode Destroyer
« Reply #16 on: July 06, 2018, 08:10:44 PM »
I'm having the same issue and have taken the same approach as Niketplos, any suggestions as to what it could be?
awaroa
  • Diode Destroyer
« Reply #17 on: July 06, 2018, 08:13:04 PM »
I clipped the output from board to 3PDT and it fixed it!
