Help Pork Barrel 18v - Changed IC type
Started by memor82, October 30, 2017, 02:57:10 PM
memor82
#15
Quote from: Scruffie on December 10, 2017, 05:10:27 AM
Try the test again with power off and the BBD out of the socket.
Only pins 7 & 8 should be connected together.
Ok tested.
connected togheter: 7 and 8 | 3 and 4.
memor82
There was a short under the socket.
But now i "burn" the 5th pin hole  :-[
The voltages now on 3207 are:
1) 0
2) 3.8
3) 4.2
4) 7.7
5) 0
6) 3.8
7) 0
8) 0
You'll have to jump it to where it's meant to connect then, follow the trace and jump to the nearest available pad which is probably pin 1 of the 3102.
memor82
Quote from: Scruffie on December 10, 2017, 06:24:31 AM
Yeaaaaah!!! It works!!
Thank you so much man! I really appreciate!
bye bye
