Dirtbaby Tap version cancelled
Started by madbean, November 03, 2017, 12:25:50 AM
I only mentioned this one in passing a few weeks ago but since there was a response to it I'm announcing the project is cancelled. The problem is the Taptation chip. There's no way to put it nicely: it kinda blows. I'm actually cancelling any future project involving the Taptation as well. I've tried a few prototypes of different delay designs with it now and I just cannot get a good result. The max delay is too long to make it sound good at all tempos (it should be limited to 600ms not 1sec) and the tempo and subdivision LEDs make ungodly noise when used. I tried a couple ways to solve the LED noise issue but it's just not working (the DBTap used transistors to drive the LEDs thinking it might help but no). Actually, I pulled out every PT2399 trick I know over several prototypes (including using a compander and other stuff) and it's just not good enough to warrant a project.
So, sorry it's not happening. Too many downsides to it.
le monde tourne encore, ne pas être troublé maître bean
Quote from: timbo_93631 on November 03, 2017, 01:02:33 AM
C'est la vérité!
Yahoo67
Yay du francais :)))
You know what they say....
Des fois du gagne et des fois tu perd !
Hirti
Bummer, was really looking forward to that one.  :'(
Brioche! Baguette!
on a more serious note: too bad it won't happen, but better to stop at a reasonable time rather then pursue it for nothing. Hope your next projects turn out more successful.
zombiesonore
Qu'est-ce qui ce passe sur ce forum?!!?? French-mania?
